Arduino Mega Programming problems
I'm having trouble programming my original Arduino Mega board via Mobiflight. There is an LED on the board at pin 13 and ground orange.
Is that normal?
Welcome to the forum
What is Mobiflight and how do you use it to program an Arduino ?
https://docs.arduino.cc/hardware/mega-2560?_gl=1*ho6hzp*_ga*ODI5MDA0NTc2LjE2NTU3NjU5MzM.*_ga_NEXN8H46L5*MTY2MjQ2NDM0MS41ODAuMS4xNjYyNDY0OTMwLjU2LjAuMA..
You can see an LED on PB7 D13
According to the google search this is what i got.
Mobiflight integrates standard hardware with your flight simulator
this allows you to build your individual cockpit in a fast, cheap and flexible way!
I have no idea how to use Mobiflight so i really dont know how to intergrate it.
But to the original poster, there is 3 LED's in that area. One is for power (Green), One is for indicating Transmitting(Yellow) and one is for indicating Recieving(Yellow)
How can I reset the arduino board so that it is in factory mode?
Why do you think you need to ?
I am trying a tutorial with mobiflight to control a switch. Use the settings as in the example.
But unfortunately that doesn't work for me. I'm using an original Arduino Mega. And see a yellow LED on the Arduino board near the USB connection.
Shouldn't that be green?
What example would that be ?
If it is an Arduino sketch then please post it here, using code tags when you do. How is the Mega connected to the PC ?
Please post a link to the tutorial that you are following
See my above post about the lights. At the USb connection there is Green for Built in Led! Yellow for transmitt and recieve. Those are nomal lights. Yellow will blink during code upload or if data is being transimitted/Recieved.
Sorry for the somewhat late response.
The problem is solved.
I am using MSFS2020 with Prosim737 and Arduino with Mobiflight.
The problem was that FSuiPC7 made the connection with MSFS2020 and Mobiflight but not with Prosim737.
After I solved that problem I was able to enter switches on again.
