arduino mega protoshield
Hello,
I've bought an arduino mega protoshield but there is something I don't understand about soldering additional wires.
Once you solder the sockets in order to plug arduino mega, the shield PCB has a layout in order to route each pin to another hole where you can then solder a wire. This is true for lateral side (pins of Analog IN and Power) and (pins of Communication and PWM)
Maybe i've missed something, once socket is soldered on the other lateral side (pins digital 22-53), there is no way to then solder a wire to a hole being routed from these pins...
Any suggestions.
Thank you, Albert
There are a number of different protoshields for the Mega. You'll need to link to a picture of the one you have.
Here is one picture of it http://docs-europe.electrocomponents.com/webdocs/0db9/0900766b80db9934.pdf
