Arduino Mega PWM 44-46 Disabled
Hello,
If I was to purchase an Arduino Due would I be able to utilize PWM pins 44-46 while using the L293D Shield?
I am currently working on a project that consists of a Arduino Mega with a L293D Shield attached.
The L293D Shield is currently controlling a small Servo and Stepper Motor. In addition to the L293D Shield I would like to utilize the PWM pins on 44-46. However, when I ".attach" the servo using the Servo.h library I believe pins 44-46 become disabled. From my research online when I attach the servo, timer 5 will be used on the Mega which will disable pins 44-46 allowing the first 12 PWM pins to be functional (which are occupied by the shield).
Do I have any other options? Does this make sense?
https://www.arduino.cc/reference/en/libraries/servo/
Allows Arduino boards to control a variety of servo motors.
This library can control a great number of servos. It makes careful use of timers: the library can control 12 servos using only 1 timer. On the Arduino Due you can control up to 60 servos.
https://arduino.stackexchange.com/questions/13415/arduino-mega-pwm-pins-stop-working-for-leds-once-servo-is-attached/13425
Thank you
