Arduino Mega Randomly Hangs (Stops)
Hello all!
I built an Arduino chicken incubator! It was working great for 4 full days, but then the dc jack connection I installed on the back of the incubator, melted to the power cord due to too much current being drawn with all of the heaters.
I actually made a tutorial, where you can see everything I did:
After I fixed that issue, my Arduino Mega is now acting strangely. When I first plug it in, it runs fine for about 5 seconds than the screen starts displaying strange characters here and there. Then after another 5 seconds, the display freezes, and nothing works.
What on earth is going on here!? I would really like to get my incubator working, but am not sure how to do that sadly :face_exhaling: .
Here is the code (which fully worked before):
#include "DFRobot_RGBLCD1602.h"
#include "DFRobot_AHT20.h"
#include <AccelStepper.h>
#include <EEPROM.h>
#define heater1 22
#define heater2 23
#define heater3 24
#define heater4 25
#define m1en 2
#define m1step 3
#define m1dir 4
#define m2en 5
#define m2step 6
#define m2dir 7
#define buzzer 8
#define blower1 9
#define blower2 10
#define touch A0
#define turningtime 120000 //2 min;   -1 means always turning, else input a millis value
float timeoffset;// = 2.1;
const byte motor1Char[8] = {
  0b00110,
  0b00110,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
const byte motor2Char[8] = {
  0b01100,
  0b01100,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
float temp=0;
float hum=0;
int normalDayCount = 18;
int hatchDayCount = 3;
unsigned long lastmillis=0;
unsigned long daymillis=86400000;
unsigned long lastdaymillis=0;
unsigned long lasticonmillis=0;
unsigned long endmillis=0;
unsigned long fanonmillis=40000;
unsigned long fanoffmillis=80000;
unsigned long lastfanmillis=0;
bool fanon = true;
int day=1;
bool icon = false;
bool mode = false;
int touchcount=0;
float lasthour=0;
DFRobot_RGBLCD1602 lcd(/*lcdCols*/16,/*lcdRows*/2);  //16 characters and 2 lines of show
DFRobot_AHT20 aht20;
AccelStepper stepper(1,m1step,m1dir); // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
  setupPinmodes();
  startSensor();
  lcd.init();
  lcd.customSymbol(1,motor1Char);
  lcd.customSymbol(2,motor2Char);
  lcd.setRGB(0,255,0);
  lcd.setCursor(0,0);
  lcd.print("Egg Incubator");
  lcd.setCursor(0,1);
  lcd.print("Version 1.0.0");
  delay(2000);
  lcd.clear();
  digitalWrite(blower1, HIGH);
  digitalWrite(m1en,LOW);// Low Level Enable
  digitalWrite(m2en,LOW);// Low Level Enable
  stepper.setAcceleration(25);
  stepper.setMaxSpeed(160);
  //EEPROM.write(8, 26);
  //EEPROM.write(7,1);
  day = EEPROM.read(7);
  float r = EEPROM.read(8);
  timeoffset = r/10;
  if (!stepper.isRunning()){
    checkTH();
    if (!mode){
      lcd.setCursor(13,0);
      lcd.print("   ");
      displayTH();
    else {
      lcd.setCursor(14,0);
      lcd.print("  ");
      displayInfo();
  else {
    if (millis() - lasticonmillis > 300){
      //lcd.setCursor(13,0);
      //lcd.print("  ");
      lcd.write(icon ? 1 : 2);
        //lcd.write(2);
      icon = !icon;
      lasticonmillis = millis();
  Serial.println("Touch: " + String(digitalRead(touch)));
  if (digitalRead(touch) == HIGH){
    while(digitalRead(touch) == HIGH){touchcount++;delay(1);}
    if (touchcount < 5000){
      mode = !mode;
      digitalWrite(buzzer, HIGH);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Mode: ");
      lcd.print(mode ? "Info" : "Temp&Hum");
      digitalWrite(buzzer, LOW);
      delay(2000);
      lcd.clear();
      touchcount=0;
    else if (touchcount >= 5000) {
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("RST to Day 1!?");
      lcd.setCursor(0,1);
      lcd.print("Hold 10 Sec = Y");
      touchcount=0;
      while(digitalRead(touch) == LOW){Serial.println("Waiting");}
      while(digitalRead(touch) == HIGH){Serial.println(touchcount);touchcount++;delay(1);}
      if (touchcount >= 10000){
        Serial.println("Resetting to day 1!");
        day = 1;
        EEPROM.write(7, day);//reset day to 1
        EEPROM.write(8, 0);//reset hour to 0
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Please Reset!");
        lcd.setCursor(0,1);
        lcd.print("Unplug...");
        while(true);
  if (day <= normalDayCount){
    Serial.println("Normal");
    standardMode();
  else if (day > normalDayCount && day <= normalDayCount+hatchDayCount){
    hatchMode();
  else {
    endMode();
  stepper.run();
  if ((millis()+((timeoffset*1000)*60*60)) - lastdaymillis > daymillis){
    day++;
    lastdaymillis = millis();
void setupPinmodes(){
  pinMode(heater1, OUTPUT);
  pinMode(heater2, OUTPUT);
  pinMode(heater3, OUTPUT);
  pinMode(heater4, OUTPUT);
  pinMode(m1en, OUTPUT);
  pinMode(m1step, OUTPUT);
  pinMode(m1dir, OUTPUT);
  pinMode(m2en, OUTPUT);
  pinMode(m2step, OUTPUT);
  pinMode(m2dir, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(blower1, OUTPUT);
  pinMode(blower2, OUTPUT);
  pinMode(touch, INPUT);
void startSensor(){
  uint8_t status;
  while((status = aht20.begin()) != 0){
    Serial.print("AHT20 sensor initialization failed. error status : ");
    Serial.println(status);
void standardMode(){
  setStandardHeater();
  setStandardRotation();
void setStandardHeater(){// the temperature we want is 95.5˚F
  if (temp < 96.50){// if temperature is less than 0.75˚ too warm
    if (temp > 96){
      digitalWrite(blower2, HIGH);
      digitalWrite(heater1, HIGH);
      digitalWrite(heater2, HIGH);
      digitalWrite(heater3, LOW);
      digitalWrite(heater4, LOW);
    else if (temp <= 96 && temp >= 95.75){
      digitalWrite(heater3, HIGH);
      if (fanon){
        if (millis() - lastfanmillis > fanonmillis){
          analogWrite(blower2, 80);
          fanon = false;
          lastfanmillis = millis();
      else {
        if (millis() - lastfanmillis > fanoffmillis){
          analogWrite(blower2, 255);
          fanon = true;
    else if (temp < 95.75 && temp >= 88){
      digitalWrite(heater4, HIGH);
      if (fanon){
          fanon = false;
      else {
          fanon = true;
    else {
  else { // if temperature is ≥ 0.75˚ too warm, shut off the heater (keep 1 on to just keep the heater warmed up)
    digitalWrite(blower2, LOW);
    digitalWrite(heater2, LOW);
void setStandardRotation(){
    if (turningtime == -1){
      stepper.move(800);
      if (hum < 25 || hum > 60){
    else {
      if (millis() - lastmillis > turningtime){
        stepper.move(800);
        lastmillis = millis();
void hatchMode(){
void endMode(){
  endmillis = millis();
  digitalWrite(heater1, LOW);
  digitalWrite(blower1, LOW);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Done!");
  lcd.print(" Check eggs");
  while(true){lcd.setCursor(0,1);lcd.print("               ");lcd.setCursor(0,1);lcd.print((millis()-endmillis)/100);delay(1000);}
void displayTH(){
  lcd.setCursor(0,0);
  lcd.print("Temp: ");
  lcd.print(temp);
  lcd.setCursor(0,1);
  lcd.print("Hum:");
  lcd.print(hum);
  lcd.print(" Day ");
  lcd.print(day);
  if (day < normalDayCount){
    if (hum < 25){
      lcd.setRGB(255,0,0);
    else if (hum > 60){
    else {
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
void displayInfo(){
  lcd.setCursor(0,0);
  lcd.print("Day ");
  lcd.print(day);
  lcd.print(" Hum:");
  lcd.print(hum,1);
  lcd.setCursor(0,1);
    if (hum < 25){
      lcd.print("Add Water!");
    else if (hum > 60){
      lcd.print("Less Water!");
    else {
      lcd.print("Doing Well!");
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
  lcd.setCursor(11,1);
  float currenthour = millis()+((timeoffset*1000)*60*60); //millis
  currenthour = currenthour/1000; //seconds
  currenthour = currenthour/60; // minutes
  currenthour = currenthour/60; // hours
  if (lasthour != currenthour){
    int d = currenthour*10;
    EEPROM.write(8,d);
  lasthour = currenthour;
  lcd.print(currenthour, 1);
void checkTH(){
  if(aht20.startMeasurementReady(/* crcEn = */true)){
    temp = aht20.getTemperature_F();
    temp = temp - 4; //temperature error correction;  currently reads 4˚ too hot
    hum = aht20.getHumidity_RH();
Thanks in advance for any ideas!
Replace any components that were damaged by the power issues, possibly including the Arduino and display. (Remove the latter two items from the chicken house and test separately with known working example programs).
It would be a great idea to update the tutorial to remove all unsafe wiring advice.
. . . ((timeoffset*1000)*60*60);
Print the calculation to see if there is a problem with integer math.
Suggest you avoid while() at all cost.
Suggest you avoid delay()
    EEPROM.write(8,d);
Will this ever be more than 255 ?
Hello kgray9
I have checked the code a little.
This sketch seems to have grown organically through nested function calls. This leads to spaghetti code and nodes in the logic that are functionally undesirable.
What to do.
There are two options.
Debug, using multiple Serial.println()'s to see what happens under different conditions. Nodes can be solved this way, but new ones can also be created in the process.
The second option is to rearrange the sketch. Based on the IPO model, structure the desired function of the sketch into basic functions. Take a sheet of paper and a pencil and draw a programme structure to identify the required functions, e.g. button, timer and display functions. All these functions can be coded and tested separately. To complete the project, you also need to design a control structure that uses events to call the above functions.
That is all that needs to be done. Try them out.
Thanks @paulpaulson , @LarryD and @jremington for the tips!
I just redid my code, and I think its better! I got rid of all whiles, and reorganized some things; including more functions.
#include <EEPROM.h>
#define heater1 22
#define heater2 23
#define heater3 24
#define heater4 25
#define m1en 2
#define m1step 3
#define m1dir 4
#define m2en 5
#define m2step 6
#define m2dir 7
#define buzzer 8
#define blower1 9
#define blower2 10
#define touch A0
  0b00110,
  0b00110,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
  0b01100,
  0b01100,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
float temp=0;
float hum=0;
bool fanon = true;
int day=1;
bool icon = false;
bool mode = false;
int touchcount=0;
int lasttouchcount=0;
bool rstday = failed
unsigned long rstcount=0;
float lasthour=0;
  setupPinmodes();
  startSensor();
  startDisplay();
  timeoffset = r;
  if (rstday){
      rstcount++;
    if (digitalRead(touch) == LOW){
      lastrstcount == rstcount;
    delay(1);//to keep a millis value; perfect timing
    if (lastrstcount != rstcount){
      if (rstcount < 10000){//10 seconds
        return;
    if (rstcount >= 10000){
      day = 1;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      while(true);
    rstday = false;
    rstcount=0;
    checkTH();
    if (!mode){
      lcd.print("   ");
      displayTH();
    else {
      lcd.print("  ");
      displayInfo();
  else {
      //lcd.print("  ");
      icon = !icon;
  lasttouchcount = touchcount;
  if(digitalRead(touch) == HIGH){
    touchcount++;
  if (lasttouchcount == touchcount){ //touch sensor is no longer high
    if (touchcount > 0 && touchcount < 5000){//5 seconds
      switchmode();
      touchcount=0;
    else {
      resetday();
      touchcount=0;
    standardMode();
    hatchMode();
  else {
    endMode();
  stepper.run();
    day++;
void startSensor(){
  uint8_t status;
void startDisplay(){
  lcd.init();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  delay(2000);
  lcd.clear();
void switchmode(){
  mode = !mode;
  lcd.clear();
  lcd.setCursor(0,0);
  delay(2000);
  lcd.clear();
void resetday(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  touchcount=0;
  rstday = true;
    if (temp > 96){
      if (fanon){
          fanon = false;
      else {
          fanon = true;
      if (fanon){
          fanon = false;
      else {
          fanon = true;
    else {
      stepper.move(800);
    else {
        stepper.move(800);
void hatchMode(){
void endMode(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Done!");
void displayTH(){
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.setCursor(0,1);
  lcd.print("Hum:");
  lcd.print(hum);
  lcd.print(" Day ");
  lcd.print(day);
    if (hum < 25){
    else if (hum > 60){
    else {
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
void displayInfo(){
  lcd.setCursor(0,0);
  lcd.print("Day ");
  lcd.print(day);
  lcd.print(" Hum:");
  lcd.print(hum,1);
  lcd.setCursor(0,1);
    if (hum < 25){
    else if (hum > 60){
    else {
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
    int d = currenthour;
    EEPROM.write(8,d);
void checkTH(){
Now I'm going to check each of my components to make sure they all work separately.
@LarryD , dang. Yep, that eeprom value will go up to 508 :man_facepalming:. I'll have to reset it halfway through.
I also just updated the tutorial (not the code yet though in my repository).
Ignore the above code; it will not compile.
Here is the correct code:
#include <EEPROM.h>
#define heater1 22
#define heater2 23
#define heater3 24
#define heater4 25
#define m1en 2
#define m1step 3
#define m1dir 4
#define m2en 5
#define m2step 6
#define m2dir 7
#define buzzer 8
#define blower1 9
#define blower2 10
#define touch A0
  0b00110,
  0b00110,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
  0b01100,
  0b01100,
  0b00100,
  0b01110,
  0b01110,
  0b01110,
  0b01110,
  0b01110
float temp=0;
float hum=0;
bool fanon = true;
int day=1;
bool icon = false;
bool mode = false;
int touchcount=0;
bool rstday = false;
unsigned long lastrstcount=0;
float lasthour=0;
  setupPinmodes();
  startSensor();
  startDisplay();
  timeoffset = r;
  if (rstday){
      rstcount++;
        return;
      day = 1;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
      while(true);
    rstday = false;
    rstcount=0;
    checkTH();
    if (!mode){
      lcd.print("   ");
      displayTH();
    else {
      lcd.print("  ");
      displayInfo();
  else {
      //lcd.print("  ");
      icon = !icon;
    touchcount++;
      switchmode();
      touchcount=0;
    else if (touchcount >= 5000){
      resetday();
      touchcount=0;
    standardMode();
    hatchMode();
  else {
    endMode();
  stepper.run();
    day++;
void startSensor(){
  uint8_t status;
  lcd.init();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  delay(2000);
  lcd.clear();
void switchmode(){
  mode = !mode;
  lcd.clear();
  lcd.setCursor(0,0);
  delay(2000);
  lcd.clear();
void resetday(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  touchcount=0;
  rstday = true;
    if (temp > 96){
      if (fanon){
          fanon = false;
      else {
          fanon = true;
      if (fanon){
          fanon = false;
      else {
          fanon = true;
    else {
      stepper.move(800);
    else {
        stepper.move(800);
void hatchMode(){
void endMode(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Done!");
void displayTH(){
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.setCursor(0,1);
  lcd.print("Hum:");
  lcd.print(hum);
  lcd.print(" Day ");
  lcd.print(day);
    if (hum < 25){
    else if (hum > 60){
    else {
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
void displayInfo(){
  lcd.setCursor(0,0);
  lcd.print("Day ");
  lcd.print(day);
  lcd.print(" Hum:");
  lcd.print(hum,1);
  lcd.setCursor(0,1);
    if (hum < 25){
    else if (hum > 60){
    else {
  else {
    if (hum < 55){
    else if (hum > 95){
    else {
    EEPROM.write(8,d);
void checkTH(){
After much testing and taking apart things, it seems that the Arduino controls the LCD, reads temperature and humidity, and runs one heater just fine when plugged into my computer. When I plug the actual power supply in though, it starts acting weird again and freezes up about 15 seconds after.
This seems to indicate that the 5V regulator has been damaged from the power issues, right?
