Arduino Mega RS485 RTU
Hi
I have an arduino mega and two sensors that talk RS485 RTU, i need to connect these sensors with the arduino to be able to write to and read from registers.
Does anyone could help me how to start? and do i need extra components?
also if i could use an arduino nano what should i do.
Thanks.
The Soil sensor
Soil sensor datasheet
Temp Sensor from here
Temperature sensor datasheet
I guess you mean Modbus RTU over RS-485.
You need an RS-485 adapter so your Mega can physically connect to the RS-485 interface.
Then you need a Modbus Master library to provide the protocol support. I suggest to use the ModbuxMaster library available in the library manager, it's relatively easy to use.
I wouldn't recommend that model as it has only one serial interface which is already used for the communication to the PC. If you don't need that connection (even not during development) you might consider it.
