Arduino Mega Serial USB not transmitting when receiving
I am new to Arduinos and I am trying to make a Mega communicate with my computer via USB using Serial.
I am sending a command from the arduino to the computer every 500ms and receiving one back from the computer every 600ms.
Now, everything works fine on an Arduino Uno.
However, if I try and run the same code on a Mega, as soon as the computer starts transmitting every 600ms, the Arduino stops transmitting its own command.
The problem vanishes if I use a frequency higher that 800ms on the computer.
Any ideas on what might be happening???
Here's the code for your reference:
  Serial.print("Hi");
Thank you very much,
Nick
This must work without a problem.You say this:
Serial.print("Hi");
Where in the code above you are implementing receiving messages from computer?
That's the thing: I didn't implement it at all but still the Mega stops transmitting if the frequency at which messages are sent to it is below 800ms!
