Arduino Mega SoftwareSerial -> RS485
Hallo Zusammen
Ich versuche verzweifelt 2 Arudino Mega mit RS485 zu verbinden.
Hierfür habe ich die SoftwareSerial und den RS485_non_blocking von Nick Library
Der Sender sendet die Signale jedoch Empfange ich nichts.
RO = GPIO 2
RE = GPIO 4
DE = GPIO 2
DI= GPIO 3
VCC = 5VCC
B = B
A = A
GND = GND
A ->560 Ohm -> VCC
B -> 560 Ohm -> VCC
Sketch sender:
#include <Wire.h>
#include <SoftwareSerial.h>
#include <RS485_non_blocking.h>
unsigned long last_millis;
unsigned long last_millis_Debug;
struct {
  byte signal1;
  byte signal2;
  byte signal3;
  byte signal4;
} message;
const int tx_enabled = 4;
SoftwareSerial rs485 (2, 3); // RX receive pin, TX transmit pin
// Set Expander
/* *** Funktion Deklarationen *** */
size_t fWrite (const byte what) {
  return rs485.write (what);
int fAvailable () {
  return rs485.available ();
int fRead () {
  return rs485.read ();
RS485 myChannel (fRead, fAvailable, fWrite, 20);
void setup ()
  Serial.begin (38400);  // Hardware Serial
  rs485.begin (9600);   // Software Serial
  myChannel.begin();
  Wire.begin();
  Serial.println("Sender");
  pinMode (tx_enabled, OUTPUT);
void loop ()
  //Test Connection Timeout
  if (millis() - last_millis >= 200) {//50
    Serial.println("sende");
    last_millis = millis();
    last_millis_Debug = millis();
    sendMessage();  // Sende-Funktion
void sendMessage()
  message.signal1 = 1;
  message.signal2 = 2;
  message.signal3 = 3;
  message.signal4 = 4;
  digitalWrite(tx_enabled, HIGH);
  myChannel.sendMsg ((byte*) &message, sizeof message); // Send my Message
  digitalWrite(tx_enabled, LOW);
Sketch Empfänger:
#include <Wire.h>
unsigned long fahrbefehl;
int fAvailable () {
int fRead () {
void setup ()
 rs485.begin (9600);
 myChannel.begin ();
 Wire.begin();
 Serial.println("Starte Empfänger");
 pinMode(13, OUTPUT);
void loop ()
 if (millis() - fahrbefehl >= 10000) {
   digitalWrite(13, HIGH);
   digitalWrite(13, LOW);
 if (myChannel.update() ) {
   digitalWrite(53, HIGH);
   byte len = myChannel.getLength();
   byte* p = myChannel.getData ();
   for (; len > 0; len--) {
     fahrbefehl = millis();
     Serial.println("Update");
Ich hoffe es sind genügend Angeben vorhanden sodass mir jemand Helfen kann.
Für eure Hilfe bedanke ich mich schon im voraus.
Gruss Schnibli
RO = GPIO 2
RE = GPIO 4
DE = GPIO 2
DI= GPIO 3
lies noch mal die Doku, so kann das meiner Meinung nicht passen.
Üblicherweise legst beide Enables - RE und DE - auf einen gemeinsamen Pin.
Stell das mal richtig und wenn es dann noch immer nicht klappt, mach bitte Bilder worauf wir die Verkabelung der Module und zwischen den Modulen sehen. So viele Fotos wie nötig. Jedes Kabel muss erkennbar und verfolgbar sein.
Außerdem ist es schon eigenartig auf einem Mega SoftSerial zu verwenden wo er doch mehrere HW-Serials hat.
Hallo Noiasca
Sorry das ist ein Tippfehler.
DE und RE sind beide auf GPIO 4
Guten Morgen,
B -> 560 Ohm -> VCC
Das ist meiner Meinung nach falsch. "B" muss mit Pulldown gegen GND geschaltet werden.
VG, Tobias
Hallo Big_t habe ich jetzt gerade so angeschlossen.
Leider kommt kein Signal an.
Hab gerade herausgefunden:
Wenn ich den Empfänger mit einem Arduino UNO ersetzte funktioniert es.
1 Arduino Mega -> Arduino Uno =Funktioniert
anderer Arduino Mega -> Arduino Uno = Funktioniert
Arduino Mega -> Arduino Mega = Funktioniert nicht
Edit:
Fehler gefunden:
Was war es nun?
und warum softserial auf einem Mega?
Das Problem könnte ganz einfach daran liegen, daß SoftwareSerial auf dem Mega nicht notwendig ist und daher nicht (richtig) unterstützt wird.
Hallo Zusammen
Da hat es leider mein Copy&Paste nicht übernommen
Die SoftwareSerial funktioniert nur auf bestimmten Pins beim Arduino mega.
Das war das Problem :slight_smile:
