I am having a problem solving this straight forward program I wrote for Arduino Mega.
#include <LiquidCrystal.h>
LiquidCrystal lcd(5,4,3,2,9,10,11);
int spump1 = 26;
int pumpB = 28;
int pumpC = 29;
int trig1 = 22;
int echo1 = 23;
int trig2 = 24;
int echo2 = 25;
int valve1 = 30;
int valve2 = 31;
// set min max on both tanks
pinMode(spump1, OUTPUT);
pinMode(pumpB, OUTPUT);
pinMode(pumpC, OUTPUT);
pinMode(trig1, OUTPUT);
pinMode(echo1, INPUT);
pinMode(trig2, OUTPUT);
pinMode(echo2, INPUT);
pinMode(valve1, OUTPUT);
pinMode(valve2, OUTPUT);
digitalWrite(spump1, LOW);
digitalWrite(pumpB, LOW);
digitalWrite(pumpC, LOW);
digitalWrite(valve1, LOW);
digitalWrite(valve2, LOW);
// Start of tank run
// sonar ping routine
long duration1, distance1;
digitalWrite(trig1, LOW);
delay(2);
digitalWrite(trig1, HIGH);
delay(10);
duration1=pulseIn(echo1, HIGH);
distance1 = (duration1/2)/29.1;
long duration2, distance2;
digitalWrite(trig2,LOW);
delay (2);
digitalWrite(trig2, HIGH);
delay (10);
digitalWrite (trig2, LOW);
distance2 = (duration2/2)/29.1;
lcd.setCursor(0,0);
lcd.print("Sanzfield 2017");
lcd.setCursor(0,1);
if (distance1 >= 90 and pumpB == LOW)
digitalWrite(spump1, HIGH);
lcd.print("Sump1 on");
else if (distance1 <= 10); //cycle start for tank B
digitalWrite (spump1, LOW);
delay (2000);
lcd.print("Sump1 off");
delay (2000);
lcd.print ("B Cycle Start");
digitalWrite(pumpB, HIGH);
delay (432000000);
lcd.print ("cycle end");
digitalWrite(valve1, HIGH); //start transfer to TankC
if (distance2 >= 10)
digitalWrite(pumpC, HIGH);
delay (3600000);
I could use some input as I am new at this and have a dead line. Please.
I just need to know if this correct in layout and function?
