Arduino mega tft buttons
I am making a system that uses the Arduino mega and a 2.4 inch tft touchscreen shield to control lights and a fan in my room. I am trying to make buttons for it that control certain pins. The only way I could get this to happen was by using a slightly modified example sketch. The issue is that I can only get 2 buttons to because that is how many the example sketch had. I am very bad at coding and hoping that someone else with more experience than me could help me add the other two buttons.
#if 1
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
// ALL Touch panels and wiring is DIFFERENT
// copy-paste results from TouchScreen_Calibr_native.ino
const int XP=8,XM=A2,YP=A3,YM=9; //240x320 ID=0x9341
const int TS_LEFT=137,TS_RT=894,TS_TOP=93,TS_BOT=893;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn;
int pixel_x, pixel_y;     //Touch_getXY() updates global vars
bool Touch_getXY(void)
    TSPoint p = ts.getPoint();
    pinMode(YP, OUTPUT);      //restore shared pins
    pinMode(XM, OUTPUT);
    digitalWrite(YP, HIGH);   //because TFT control pins
    digitalWrite(XM, HIGH);
    bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
    if (pressed) {
        pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
        pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
    return pressed;
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
void setup(void)
    uint16_t ID = tft.readID();
    Serial.print("TFT ID = 0x");
    Serial.println(ID, HEX);
    Serial.println("Calibrate for your Touch Panel");
    if (ID == 0xD3D3) ID = 0x9486; // write-only shield
    tft.begin(ID);
    tft.setRotation(0);            //PORTRAIT
    tft.fillScreen(BLACK);
    on_btn.initButton(&tft,  60, 290, 100, 40, WHITE, CYAN, BLACK, "ON", 2);
    off_btn.initButton(&tft, 180, 290, 100, 40, WHITE, CYAN, BLACK, "OFF", 2);
    on_btn.drawButton(false);
    off_btn.drawButton(false);
   pinMode(22, OUTPUT);
/* two buttons are quite simple
void loop(void){
    tft.setTextColor(WHITE);
    tft.fillRect(0, 230, 240, 3, BLUE);
    tft.fillRect(0, 317, 240, 3, BLUE);
    tft.fillRect(0, 0, 240, 3, BLUE);
    tft.fillRect(237, 0, 3, 320, BLUE);
    tft.fillRect(0, 0, 3, 320, BLUE);
    tft.setCursor(65, 240);
    tft.setTextSize(2);
    tft.print("Fan Control");
    bool down = Touch_getXY();
    on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
    off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
    if (on_btn.justReleased())
        on_btn.drawButton();
    if (off_btn.justReleased())
        off_btn.drawButton();
    if (on_btn.justPressed()) {
        on_btn.drawButton(true);
        digitalWrite(22, HIGH);
    if (off_btn.justPressed()) {
        off_btn.drawButton(true);
        digitalWrite(22, LOW);
#endif
this might help.
https://forum.arduino.cc/index.php?topic=530167.0
That was helpful I might have figured it out.
