Arduino Mega to ESP8266 Serial communication problem
Hello, There !
In one of the my project, I am trying to establish serial communication between Arduino Mega-2560 (Master) and ESP8266(Slave). In that case i am able to get shared data(0xD414) by Arduino to read over ESP8266 , but unfortunately i am unable to find from where getting the "0" value initially at the shared value. Can anyone suggest me how to remove "0" from the original value. That is (0D4, 014) instead of D4 and 14 after receiving data
Here it is the snapshot of result: Picture
Master Code
uint16_t adcvalue = 0xD414;
  Serial.write(highByte(adcvalue)); //Write the serial data
  Serial.write(lowByte(adcvalue)); //Write the serial data
  delay(100);
Slave Code:
uint32_t adcvalue ;
  adcvalue = Serial.read();
  Serial.print(highByte(adcvalue),HEX);
  Serial.println(lowByte(adcvalue),HEX);
  delay(100);
There is a sticky on how to post pictures.
  delay(100);
Serial.write writes the individual bytes.
  delay(100);
Serial.read() only reads 1 byte, The ‘highByte()’ is never actually in the variable.
You are also not making sure there is anything to be read, but that is a different matter.
Let’s assume there is for now. then
  adcvalue = (adcvalue << 8) | Serial.read();  // shift the first byte 8 bits left and add (or 'or') the next byte
  delay(100);
