Arduino MEGA - Upload Sketch Error: Timing out - SOLVED
Hi everyone. I'm new to the forum but not to Arduino per se. I've never encountered an upload problem before but at the same time I have never had a project that required the Mega.
Problem: It seems my Mega is timing out during uploading but I can't seem to find why it's happening.
EDIT:
I kept searching the forums and found a post saying that we should be wary of using USB3.0 ports for uploads as there are supposed issues with USB3.0. I found this odd because I never encountered an error while flashing UNO, Nano and NodeMCU but I tried it and changing the port from USB3.0 to USB2.0 SOLVED this issue and allowed me to upload my sketch.
I was going to delete this post but I find others might encounter this issue so I will leave it up to the mods to decide if its unecessary. Thank you and sorry for the inconvenience.
Original Post Continued:
Things I have already tried:
  1. At first, I thought it was the sketch size (12% of capacity), so I tried uploading blink example, but it also caused an upload error.
  2. Then I tried searching these forums (and google) - Some people had a "similar" problem, but their solutions haven't proven to do anything in this case.
  3. Lastly, I tried the loopback test - It seems the loopback test didn't work. For reference this is the test I followed. Loop-Back Test Instructions - Installation & Troubleshooting - Arduino Forum
I attached the error message and would appreciate any help and/or orientation with how to solve this. Thank you all in advance.
P.S. I managed to flash my nano, uno and nodemcu esp8266 micros so It seems my PC might not be the problem.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 1536 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM5 -b115200 -D -Uflash:w:C:\Users\kevin\AppData\Local\Temp\arduino_build_43749/Blink_Example.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM5"
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
option enabled in File -> Preferences.
