Arduino Mega, USB host shield and SD card Module
I have a problem with my arduino
My hardware is:
Arduino Mega (ATmega2560)
Arduino USB Host Shield (Accessories — Arduino Official Store)
Arduino SD Card Module (Micro SD Card Adapter - Catalex v1.0)
I tried to connect the SD Card Module to the Arduino Mega (without the Arduino USB Host Shield) by using the SPI pins (50, 51, 52, 53) and I loaded an example sketch (File >> Examples >> SD >> cardInfo):
  SD card test
  This example shows how use the utility libraries on which the'
  SD library is based in order to get info about your SD card.
  Very useful for testing a card when you're not sure whether its working or not.
  The circuit:
    SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
 		Pin 4 used here for consistency with other Arduino examples
  created  28 Mar 2011
  by Limor Fried
  modified 9 Apr 2012
  by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 53;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("Card type:         ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  Serial.print("Clusters:          ");
  Serial.println(volume.clusterCount());
  Serial.print("Blocks x Cluster:  ");
  Serial.println(volume.blocksPerCluster());
  Serial.print("Total Blocks:      ");
  Serial.println(volume.blocksPerCluster() * volume.clusterCount());
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("Volume type is:    FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  Serial.print("Volume size (Kb):  ");
  Serial.println(volumesize);
  Serial.print("Volume size (Mb):  ");
  volumesize /= 1024;
  Serial.print("Volume size (Gb):  ");
  Serial.println((float)volumesize / 1024.0);
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
And it worked perfectly. Then I tried to connect the Arduino USB Host Shield. I had the SD Card Module connected to the Arduino USB Host Shield only by to two cables (VCC and GND). I loaded the sketch and this time, once I've opened the Serial Monitor, it gave me an error:
Initializing SD card...initialization failed. Things to check:
So I searched on the Internet for some solution, but all the solution I found, didn't work with me. Reading on some forums, I thought that the problem was the CS pin: in fact the Arduino USB Host Shield - as I read - uses the pin 10 on the Arduino Mega as CS pin. Some solution I found say to connect the CS pin of the SD Card Module to the pin 4 on the Arduino USB Host Shield. I tried to do that, but it didn't work (I changed chipSelect to 4), so I tried to connect the CS pin of the SD Card Module to each pin of the Arduino USB Host Shiled (I did it by changing the chipSelect each time), but it didn't worked. :confused:
Have you got any solution?
P.S.
Sorry for my Engilsh
I have the same problem. Been reading other solutions and found the same suggestion but it didn't work.
