I put delay back on.
byte lighton[] = {0b1100, 0b1100, 0000, 0001};
Serial1.write(lighton, sizeof(lighton));
delay(10000);
Now
If it is off, then it will not go on.
If it is on, then it will turn off.
Wen
delay(10000);
Now
Wen
Maybe the "CC01" sent from your tester is just two bytes.
Try changing your array to have just this ...
0xCC, 0x01
Hi Hackscribble,
Thank you for not giving up on me.
byte lighton[] = {0xCC, 0x02};
delay(5000);
I tried but still not working.
Wen
byte lighton[] = {0xCC, 0x01};
not working
Just to confirm a couple of things ...
In your original post, this code turned the light OFF (if it was on) but would not turn it ON. Is that right?
byte lightonoff[] = {1100, 1100, 0000, 0001};
Serial1.write(lightonoff, sizeof(lightonoff));
delay(10000);
In a later post, the new code below turned the light ON (if it was off) but would not turn it OFF?
// read from port 1, send to port 0:
OR
byte lighton[] = {0xC, 0xC, 0x0, 0x01};
delay(10000);
And the latest code, sending just two bytes, does that do anything to the lamp?
Thanks
Ray
Do you have a link to any information about the device? I'm wondering if there is documentation on the commands it accepts.
