Arduino Mega with 2 servos
Hello,
I want to control 2 servos using a Arduino Mega. The mega is connected to the PC using a USB cable and I've also connected an external powersupply to the mega.
The servos are connected to pin 9 and 10 of the Arduino Mega.
The servos are powered using an external stabilized power supply (5 V). The Brown wire to the ground, the red wire to 5 V and the orange wire to Pin 9 of the Mega.
When I power up the power supply the servos move a little bit but when I use the following code nothing happens?
I've used this code to test 1 servo:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  Serial.begin(9600);      // opens serial port, sets data rate to 9600 bps
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
    Serial.print("Hello World!");
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Nothing happens using this code :-* I have also tried increased delay values but also without succes......
Is there a way to see if the Pin 9 gives a signal? (I don't have a Oscilloscope) Am I overlooking something obvious?
Thanks in advance :slight_smile:
Do you have a common ground? The external power supply ground, Arduino ground, and servo ground must all be connected.
-j
No I have not got a common ground. How do I realize this?
BTW: I have removed the external power supply of the Mega. So I just have the external power supply for the servos and the USB power of the Mega.
And I have connected the power supply ground with a wire to the ground to the arduino (in the power area of the arduino). Is this the right way to make a "common ground"?
I have tested the setup again but still without succes.......
Thanks in advance.
Yes, that will work.
-j
Yes, the external power supply ground should be wired to one of the Gnd pins on the Mega.
for the Mega, try connecting the servo to pin 11 instead of 9 and change the code to Servo.attach(11);
(Timer1 PWM pins are on 11 and 12 on the Mega)
Ok, I've created a common ground and also tried to run the code with the servo pin connected to pin 11.
Still the servo does not work..... I have tested pin 9 (PWM) using the fading tutorial with a led and this works :slight_smile:
The servo works with the following specs:
impulse length = 0.9 ms to 2.1 ms (neutral at 1.5 ms)
Impulse frequency = 50 Hz (20 ms)
Is it possible to connect a servo directly to the Mega board?
In the specs I've read the output can maximal handle 40 mA
pins 9 and 10 on the mega use timer4 for PWM. The Arduino Servo library uses Timer1, which as I said in the earlier post uses pins 11 and 12 on the Mega.
I suggest you test your servo using this library: Arduino Playground - Servo
It doesn't use a timer so it will be a good test to see if the servo itself is working. If you can't get the servo to work with that code then problem is either with the servo, the wiring or power. Once you do get the servo working we can see if we can get it going with the Arduino library (or you could try this one: Arduino Playground - MegaServo )
Good luck!
I've used the mega servo library and this works :). I have connected one servo to pin 2. So now I know the servo works :slight_smile:
I have also tried pin 11 and 12 with the servo library but this doesn't work. Is it possible a error in the library of is there something wrong with with my mega?
Update:
I have also tried to connect the servo to pins 9 and 11 using the MegaServo library and this also works.
In Arduino 0016 and earlier, the Servo library uses functionality built in to the hardware, and works only on pins 9 and 10 (and does not work on the Arduino Mega). In this case, if only one servo is used, the other pin cannot be used for normal PWM output with analogWrite(). For example, in Arduino 0016 and earlier, you can't have a servo on pin 9 and PWM output on pin 10.
maybe ?
