there he is again .. in one tap
//DHT22 Temperature & Humidity Sensors
#include <DHT.h>
#include <Wire.h>
//Constants
#define DHTPIN1 8 // ------ out
#define DHTPIN2 13 // ------ in
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht1(DHTPIN1, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
DHT dht2(DHTPIN2, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
//Variables
int chk ;
int dhtCount;
float hum1 ; //Stores humidity 1 value
float temp1 ; //Stores temperature 1 value
float hum2 ; //Stores humidity 2 value
float temp2 ; //Stores temperature 2 value
//LCD
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = A1, en = A2, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//Load Cell
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 49;
const int LOADCELL_SCK_PIN = 48;
HX711 scale;
float weight ;
float Weight ;
//Air Flipping Fan
#define fan A0
//SD Card
#include <SPI.h>
#include <SD.h>
File dataFile ;
//DS1307 RTC Time & Clock
#include <TimeLib.h>
#include <DS1307RTC.h>
// push Button
const char Button = 6 ;
bool Pressed = false ;
// UV Light Sensor
#include "Adafruit_VEML6070.h"
Adafruit_VEML6070 uv = Adafruit_VEML6070();
int Heat_Lamp = 10 ;
/* Timming Setup */
const unsigned long event_1_time = 1000 ; // DHT22 Temperature & Humidity Sensors ( 1s )
const unsigned long event_2_time = 20000 ; // DC fan OFF" ( 20s )
const unsigned long event_3_time = 80000 ; // DC fan ON' ( 1m )
const unsigned long event_4_time = 5000 ; // LCD Refresh ( 5s )
const unsigned long event_5_time = 250 ; // Load Cell Weight ( 0.25s )
const unsigned long event_6_time = 300000 ; // SD Card Saving Time ( 5m )
const unsigned long event_7_time = 1000 ; // UV Light Sensor ( 1s )
unsigned long Previous_1_time = 0 ;
unsigned long Previous_2_time = 0 ;
unsigned long Previous_3_time = 0 ;
unsigned long Previous_4_time = 0 ;
unsigned long Previous_5_time = 0 ;
unsigned long Previous_6_time = 0 ;
unsigned long Previous_7_time = 0 ;
//Serial.begin(9600);
LCD_Setup();
for (int i = 7 ; i >= 0 ; i-- )
lcd.clear ();
lcd.setCursor (i, 0) ;
lcd.print("Welcome To ..");
delay (500);
lcd.setCursor (0, 1);
lcd.print(" Drying ");
lcd.setCursor (0, 2);
lcd.print(" Agri. Products ");
lcd.setCursor (0, 3);
lcd.print(" by Green House ");
delay (5000);
lcd.clear ();
RTC_Loop ();
delay (2000) ;
PB_Setup ();
DHT_Setup ();
UV_Setup ();
FFan_Setup ();
LC_Setup ();
SD_Setup ();
HL_Setup ();
uint16_t line = 1 ;
void print2digits_sd(int number_sd) {
if (number_sd >= 0 && number_sd < 10) {
dataFile.write('0');
dataFile.print(number_sd);
void print2digits(int number) {
if (number >= 0 && number < 10) {
lcd.write('0');
lcd.print(number);
void DHT_Setup () {
dht1.begin();
dht2.begin();
void DHT_Loop () {
switch( dhtCount)
case 0:
//Read data and store it to variables hum and temp
hum1 = dht1.readHumidity();
temp1 = dht1.readTemperature();
//Print temp and humidity values to LCD
lcd.setCursor(0, 0);
lcd.print("Humidity O: ");
lcd.print(hum1);
lcd.print(" %");
lcd.setCursor(0, 1);
lcd.print("TempO: ");
lcd.print(temp1);
lcd.print(" Celsius");
case 1:
hum2 = dht2.readHumidity();
temp2 = dht2.readTemperature();
lcd.print("Humidity I: ");
lcd.print(hum2);
lcd.print(" %");
lcd.print("TempI: ");
lcd.print(temp2);
dhtCount++;
if( dhtCount > 1)
dhtCount = 0;
//Air Flipping Fan
void FFan_Setup (){
pinMode ( fan , OUTPUT );
void FFan_ON_Loop (){
digitalWrite (fan , HIGH );
void FFan_OFF_Loop (){
digitalWrite (fan , LOW );
//Heat Green House Air By Lamp
void HL_Setup (){
pinMode ( Heat_Lamp , OUTPUT );
void HL_ON_Loop (){
digitalWrite ( Heat_Lamp , HIGH );
void HL_OFF_Loop (){
digitalWrite ( Heat_Lamp , LOW );
//LCD
void LCD_Setup(){
lcd.begin(20,4);
void LCD_Loop (){
lcd.begin(20,4);
//Load Cell
void LC_Setup (){
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN) ;
scale.set_scale(115.50) ; // this value is obtained by calibrating the scale with known weights; see the README for details
//scale.tare(50) ; // reset the scale to 0
void LC_Loop (){
weight = scale.get_units()+( scale.get_units()* 0.0159 ) ; // Correction Value " 2%"
if(weight <= 5.0)
weight = 0.0;
if(weight<1000)
//lcd.clear();
lcd.setCursor(0, 3);
lcd.print("Weight = ");
lcd.print(weight); //(000.00)
lcd.print(" g ");
if(weight>=1000)
//lcd.clear();
Weight = weight/1000;
lcd.print("Weight = "); //(00.00)
lcd.print(Weight);
lcd.print(" kg ");
// push Button
void PB_Setup (){
pinMode ( Button , INPUT_PULLUP );
void PB_loop (){
bool Button_State = digitalRead (Button) ;
if ( Button_State == Pressed ){
delay (10000); // Hold Down Timing ( 10s )
void RTC_Setup (){
void RTC_Loop (){
tmElements_t tm ;
if (RTC.read(tm)) {
lcd.print("Time :");
lcd.setCursor(6, 1);
print2digits(tm.Hour);
lcd.write(':');
print2digits(tm.Minute);
lcd.write(':');
print2digits(tm.Second);
if ( tm.Hour > 12 ){
lcd.write(" PM");
else {lcd.write(" AM");}
lcd.setCursor(0,2);
lcd.print("Date :");
lcd.setCursor(8,3);
lcd.print(tm.Day);
lcd.write('/');
lcd.print(tm.Month);
lcd.write('/');
lcd.print(tmYearToCalendar(tm.Year));
//SD Card
void SD_Setup (){
lcd.clear ();
lcd.setCursor (0,0);
lcd.print("Initializing SD card");
delay (5000);
if (!SD.begin()) {
lcd.setCursor (0,1);
lcd.print("initialization ");
lcd.setCursor (0,2);
lcd.print(" failed!");
delay (2000);
while (1);
lcd.clear ();
lcd.setCursor (0,3);
lcd.print("initialization done.");
delay (2000);
lcd.clear ();
void SD_Loop (){
dataFile = SD.open("dry.TXT", FILE_WRITE);
tmElements_t tm ;
if (RTC.read(tm)) {
dataFile.print(line++);
dataFile.print(". Time : ");
print2digits_sd(tm.Hour);
dataFile.write(':');
print2digits_sd(tm.Minute);
print2digits_sd(tm.Second);
dataFile.write(' ');
dataFile.write(" PM ");
else {dataFile.write(" AM ");}
dataFile.write(',');
dataFile.print(" Date : ");
dataFile.print(tm.Day);
dataFile.write('/');
dataFile.print(tm.Month);
dataFile.print(tmYearToCalendar(tm.Year));
dataFile.print(" : Temperature Out = ");
dataFile.print(temp1);
dataFile.print(" °C , Humidity Out = ");
dataFile.print(hum1);
dataFile.print(" %");
dataFile.print(" || Temperature In = ");
dataFile.print(temp2);
dataFile.print(" °C , Humidity In = ");
dataFile.print(hum2);
dataFile.print(" || UV light level: ");
dataFile.print(uv.readUV());
//dataFile.print(" lux ");
if(weight <= 5.0)
weight = 0.0;
if(weight<1000)
dataFile.print(" || Weight = ");
dataFile.print(weight);
dataFile.println(" g");
if(weight>=1000)
dataFile.print(Weight);
dataFile.println(" kg");
dataFile.close();
// UV Light Sensor
void UV_Setup (){
uv.begin(VEML6070_1_T); // pass in the integration time constant
void UV_Loop (){
lcd.setCursor(0, 2);
lcd.print("UV light level: ");
lcd.print(uv.readUV());
PB_loop ();
if ( temp2 <= 35.0 ) {
HL_ON_Loop ();
if ( temp2 >= 40.0 ) {
HL_OFF_Loop ();
/* start record time with millis */
unsigned long Current_time = millis ();
//DHT22 Temperature & Humidity Sensors .. " 1 "
if (Current_time - Previous_1_time >= event_1_time ) {
DHT_Loop ();
Previous_1_time = Current_time ;
//Air Flipping Fan.. " 2 , 3 "
if (Current_time - Previous_2_time >= event_2_time ) {
FFan_ON_Loop ();
Previous_2_time = Current_time ;
if (Current_time - Previous_3_time >= event_3_time ) {
FFan_OFF_Loop ();
Previous_3_time = Current_time ;
// LCD .. " 4 "
if (Current_time - Previous_4_time >= event_4_time ) {
LCD_Loop ();
Previous_4_time = Current_time ;
//Load Cell .. " 5 "
if (Current_time - Previous_5_time >= event_5_time ) {
LC_Loop ();
Previous_5_time = Current_time ;
//SD Card .. " 6 "
if (Current_time - Previous_6_time >= event_6_time ) {
SD_Loop ();
Previous_6_time = Current_time ;
//UV Light Sensor .. " 7 "
if (Current_time - Previous_7_time >= event_7_time ) {
UV_Loop ();
Previous_7_time = Current_time ;
