system
October 20, 2011, 1:48am
1
i got arduino mega and i am welling to use avr studio to program it. i make my hex file but can't figure out how to upload it to the arduino.
all my attempt to upload using avrdude failed with some sort of an error.
do i need a programmer hardware unit like stk600 ?
system
October 20, 2011, 10:50am
2
Can you upload to the Mega using the Arduino IDE?
docesam:
No, I upload sketches, through the Arduino IDE, all the time to my Mega. However "some sort of error" isn't very helpful. Can you copy and paste the error?
system
October 20, 2011, 5:39pm
5
docesam:
i do press control c to terminate the error message
Can you describe how you've wired it up to do that? You've told avrdude that you have a stk500 programmer. Do you?
system
October 20, 2011, 9:40pm
7
no ,i am connecting the arduino mega via USB. however i saw some tutorial somewhere doing that telling the the arduino have got stk500 bootloader
wrong ?
Actually I think the Mega uses the stk500v2 protocol (allows for larger sketches). If you add this line to your preferences.txt file:
upload.verbose=true
... then you can see what it generates. In my case, to upload the Blink sketch it was:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P/dev/tty.usbmodemfa1341 -b115200 -D -Uflash:w:/var/folders/1l/43x8v10s1v36trvjz3v92m900000gn/T/build4052404889588940414.tmp/Blink.cpp.hex:i
This was on a Mac. Simplifying the path names a bit it would be:
avrdude -Cavrdude.conf -v -v -patmega2560 -cstk500v2 -P/dev/tty.usbmodemfa1341 -b115200 -D -Uflash:w:Blink.cpp.hex:i
So breaking that down:
Command: avrdude
Configuration file: -C avrdude.conf
Verbose output: -v -v
Device: -p atmega2560
Protocol: -c stk500v2
Port: -P /dev/tty.usbmodemfa1341 (in my case)
Baud rate: -b 115200
Disable auto-erase of flash: -D
Upload and write file to flash: -Uflash:w:Blink.cpp.hex:i
system
October 21, 2011, 4:03am
9
it turns out that i was using avrdude.exe at "C:\WinAVR-20100110" ,when i switched it to the one whic came with arduino IDE it worked !!
what is the difference between those 2 ?
thank you very much
