Arduino Mega with dc motor and rotary encoder with Syren50
hello
iam new with Arduino and mcu, i have a challenge with a project, i need to control a DC motor with rotary encoder and Syren50 with 2 limited switch for the safety, after i write the code i can read from the encoder between 0-500 the problem is after i connect it with the Syren50 on TX pin i can’t read the right numbers from the encoder, i tried different baud rate to the Syren this is my code:
#include <RotaryEncoder.h>
#include <Sabertooth.h>
const int switch1PinR = 11;
const int switch2PinL = 12;
int monitoringR;
int monitoringL;
int IsMotorOn=0;
bool FirstTime = false;
Sabertooth SR(128);
int speedF=30;
int speedB=-30;
int speedS=0;
RotaryEncoder encoder(18, 19);
SabertoothTXPinSerial.begin(9600);
  // SR.autobaud();
 pinMode(switch1PinR,INPUT);
 pinMode(switch2PinL,INPUT);
 Serial.println("SimplePollRotator example for the RotaryEncoder library.");
int DecCounter = 0;
monitoringR =digitalRead(switch1PinR);
monitoringL =digitalRead(switch2PinL);
static int pos = 0;
encoder.tick();
int newPos = encoder.getPosition();
if (pos != newPos) {
Serial.println("-------");
Serial.println(newPos);
pos = newPos;
DecCounter=pos;
// Serial.println(DecCounter);
//Serial.println(DecCounter);
//Serial.print(monitoringL);
//Serial.println();
if((monitoringR==1) || (monitoringL==1))
  IsMotorOn=1;
  IsMotorOn=0;
if(IsMotorOn==1)
   //   StartBackAndForth(pos);
// StartBackAndForth(-100);
//Serial.println(IsMotorOn);
//Serial.println(pos);
int Direction=0;
void StartBackAndForth(int EnCPos)
    if(FirstTime==false){
           SR.motor(1,speedF);
           FirstTime=true;
           Direction=0;
      if ((EnCPos <= 25) || (Direction==0))
           SR.motor(1,speedF);
           Direction=0;
      if ((EnCPos >= 330) || (Direction==1))
          SR.motor(1,speedB);
          Direction=1;
in attachment my project picture
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
You need to post links to the non-core libraries that you are using.
You need to read the stickies at the top of the forum, and fix your post to post the code correctly.
  // put your main
The only justification for putting the { on the same line as the function/statement is to save real estate. You look pretty stupid wasting real estate with white space after doing that.
Put EVERY { on a line BY ITSELF.
Put EVERY } on a line BY ITSELF.
Use Tools + Auto Format before deleting the code from your post and posting it correctly.
hello
int monitoringR;
int monitoringL;
int IsMotorOn=0;
Sabertooth SR(128);
int speedF=30;
int speedB=-30;
int speedS=0;
   Serial.println("SimplePollRotator example for the RotaryEncoder library.");}
int DecCounter = 0;
    static int pos = 0;
    encoder.tick();
       //Serial.println();
    pos = newPos;
    DecCounter=pos;
   // Serial.println(DecCounter);}
  IsMotorOn=1;}
else{
  IsMotorOn=0;}
if(IsMotorOn==1){
    //StartBackAndForth(pos);}
int Direction=0;
           SR.motor(1,speedF);
           FirstTime=true;
           Direction=0; }
           SR.motor(1,speedF);
           Direction=0;  }
          SR.motor(1,speedB);
          Direction=1; }  }
Can you post a schematic of your project to show all the parts and how they are connected?
Threads merged.
