Hello Sir,
I am trying to to build a project to power ON/OFF Home LIght and devices with web page… I have tried with the following code but working only in PIN 2-9 but its not working on pin 15 - 53. what should i do to work on thouse PIN… As i need control 32 Relay i need to use thouse PIn too… Please help me…
I have used
Arduino Mega 2560
Ethernet Shield
4 X 8 Channel Relay
here is my code
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x2B, 0x7B }; // MAC address
IPAddress ip(10,0,0, 20); // IP address
EthernetServer server(80);
char char_in = 0; // used to store a character from the Ethernet port
String HTTP_req; // stores the received HTTP request
const byte LED_pins[] = {2, 3, 4, 5, 6, 7, 9}; // Arduino pins used as ouputs for LEDs
byte LED[sizeof(LED_pins)] = {0}; // the state of each LED
Ethernet.begin(mac, ip);
server.begin();
// set up the LED pins as outputs
for (byte index = 0; index < sizeof(LED_pins); index++) {
pinMode(LED_pins[index], OUTPUT);
if (client) {
while (client.connected()) {
if (client.available()) {
char_in = client.read(); // get a single character from the Ethernet port
HTTP_req += char_in; // build a string out of the received characters
// answer first HTTP request immediately
if (char_in == '\n') {
// respond to HTTP request
client.println("Content-Type: text/html");
client.println();
CheckLEDs(); // get state of LED checkboxes from web page
DisplayLEDs(&client); // display checkboxes on web & write to LEDs
HTTP_req = ""; // delete string contents
client.stop();
} // end if (char_in == '\n')
} // end if (client.available()
} // end while (client.connected())
} // end if (client)
// get the state of the LED checkboxes from the HTTP request
void CheckLEDs()
for (byte led_num = 0; led_num < sizeof(LED_pins); led_num++) {
if ((HTTP_req.charAt(9) == (LED_pins[led_num] + '0')) &&
(HTTP_req.charAt(16) == (LED_pins[led_num] + '0'))) { // LED box is checked
LED[led_num] = 1;
else if (HTTP_req.charAt(9) == (LED_pins[led_num] + '0')) { // LED box is unchecked
LED[led_num] = 0;
// write the HTML that includes the state of the LED checkboxes for displaying on the web browser
void DisplayLEDs(Client *client)
// some CSS in the HTML to change colours and position of the box containing the LED checkboxes
client->print("<div style=\"background:white; color:green; position: absolute; margin:20px; border: grey solid 2px; padding:0 10px 4px 10px;\">");
client->print("<h1 style=\"font: normal 20px/150% Verdana, Arial, Sans-serif;\">LED Outputs</h1>");
// send each LED checkbox in turn
// use hidden checkbox so that unchecking a checkbox sends a value to the Arduino
// if only a normal checkbox is used, nothing is sent when it is unchecked
// both hidden and normal checkboxes are produced here for each LED
client->print("<form> <input type=\"hidden\" name=\"LED");
client->print(LED_pins[led_num], DEC);
client->print("\" value=\"0\"> <input type=\"checkbox\" name=\"LED");
client->print("\" value=\"");
client->print("\"");
// write to the LED connected to the Arduino board
if (LED[led_num]) {
client->print(" checked "); // part of HTML if checkbox is to be displayed checked
digitalWrite(LED_pins[led_num], HIGH); // switch LED on
else {
digitalWrite(LED_pins[led_num], LOW); // switch LED off
client->print(" onclick=\"submit();\">LED");
client->print(" </form>"); // end of HTML for 1 LED's form
client->print("</div>"); // end of box containing LEDs
Thanks for you help in advance…
