Arduino mega with fingerprint sensor Serial error
hi friend…
i have create coding for fingerprint with arduino mega and use hardware serial.
this coding already create last year and all work fine.
but after i try use this coding for same project during compile or verify it error with
no matching function for call to `Adafruit_fingerprint::Adafruit_fingerprint(HardwareSerial*)
can anyone help check my coding?..thanks…
#include <Adafruit_Fingerprint.h>
//#include <SoftwareSerial.h>
uint8_t id;
uint8_t getFingerprintEnroll();
// Software serial for when you dont have a hardware serial port
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// On Leonardo/Micro/Yun, use pins 8 & 9. On Mega, just grab a hardware serialport
 //SoftwareSerial mySerial(19, 18); // use for UNO
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial); // use for UNO
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
  Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1); // #19 is green wire, #18 is white on MEGA
// serial1 for mega pin 19,18 pls check MEGA spec
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  Serial.println("Adafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
uint8_t readnumber(void) {
  uint8_t num = 0;
  boolean validnum = false;
  while (1) {
    while (! Serial.available());
    char c = Serial.read();
    if (isdigit(c)) {
       num *= 10;
       num += c - '0';
       validnum = true;
    } else if (validnum) {
      return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as...");
  id = readnumber();
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
Unfortunately the current version of Adafruit_Fingerprint doesn't support the use of HardwareSerial, it only works with that horrible SoftwareSerial. You might change that by replacing every occurrence of SoftwareSerial by HardwareSerial in the library files.
ooo..ok2 thanks friends..
