Arduino Mega with integrated antenna GSM Shield not working
When I run the program, I can see the “GSM networks scanner” message appear on my serial monitor, but it does not display anything else after that. Also, the NET and STATUS LEDs turn off after some few seconds when the program starts running. I already made the minor adjustments necessary for the Arduino Mega, and the power supply is temporarily from the USB port of my laptop connected to the Arduino Mega. I am using a SIM card that has been activated.
This is the program that I am using:
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER “”
// initialize the library instance
GSM gsmAccess; // include a ‘true’ parameter to enable debugging
GSMScanner scannerNetworks;
GSMModem modemTest;
// Save data variables
String IMEI = “”;
// serial monitor result messages
String errortext = “ERROR”;
// initialize serial communications and wait for port to open:
Serial.println(“GSM networks scanner”);
scannerNetworks.begin();
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected) {
if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
notConnected = false;
Serial.println(“Not connected”);
// get modem parameters
// IMEI, modem unique identifier
Serial.print(“Modem IMEI: “);
IMEI = modemTest.getIMEI();
IMEI.replace(”\n”, “”);
if (IMEI != NULL) {
Serial.println(IMEI);
// scan for existing networks, displays a list of networks
Serial.println(“Scanning available networks. May take some seconds.”);
Serial.println(scannerNetworks.readNetworks());
// currently connected carrier
Serial.print("Current carrier: ");
Serial.println(scannerNetworks.getCurrentCarrier());
// returns strength and ber
// signal strength in 0-31 scale. 31 means power > 51dBm
// BER is the Bit Error Rate. 0-7 scale. 99=not detectable
Serial.print(“Signal Strength: “);
Serial.print(scannerNetworks.getSignalStrength());
Serial.println(” [0-31]”);
It would be great if you could be more specific when providing helpful information.
P.S. when I run the program without inserting a SIM card, the NET and STATUS LEDs keep on working (NET is blinking, while STATUS remains ON)
I tried this program as well https://www.arduino.cc/en/Guide/ArduinoGSMShield#toc9
and it has the same problem
SOLUTION: To solve my GSM shield issue, I connected a 9 V battery to my Arduino as a supply instead of using my Laptop’s USB cable (and I also tried a 12 V supply as well). Thankfully, it did work. In the case that that it does not work (after uploading the program), click on the ‘restart’ button found on the GSM shield. You can find the type of sources that I used to supply my Arduino & GSM shield in the image posted below. IT IS IMPORTANT TO MENTION THAT THE FOLLOWING PROGRAM WAS IMPLEMENTED TO CHECK IF THE GSM SHIELD IS WORKING (I tried the “GSM Networks Scanner” program that I have mentioned in my question initially, but it did not work and it was not necessary anyways. So, I used the ‘GSM SMS’ code directly and it worked fine)
This is the code that worked out with me:
#include <GSM.h>
GSM gsmAccess; // include a ‘true’ parameter for debug enabled
GSM_SMS sms;
// char array of the telephone number to send SMS
// change the number 1-212-555-1212 to a number
// you have access to
char remoteNumber[20]= “Replace this text with a mobile number instead”;
// char array of the message
char txtMsg[200]=“Hello World”;
Serial.println(“SMS Messages Sender”);
// connection state
// Start GSM shield
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
Serial.println(“GSM initialized”);
sendSMS();
// nothing to see here
void sendSMS(){
Serial.print("Message to mobile number: ");
Serial.println(remoteNumber);
// sms text
Serial.println(“SENDING”);
Serial.println(“Message:”);
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNumber);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
