Arduino Mega with mp3 gives too weak sound
I am worhing with Arduino Mega, speaker H1283
and DFPlayer mini: DFR0299.
However the sound comes out too low.
I need to use sine waves, with frequency (close to) 10kHz and 5kHz, with duration of 5 milliseconds.
I also need to create an envelope to the sound (fade in and fade out to prevent the "TICS" at the beginning and end of the sound).
I thought that maybe creating the sound in tje arduino itself and not playing then through the mp3 will give better results?
Is there a way to implement such sounds in Arduino mega?
If yes, does anyone know where I can find a reference to such implementation
(I am a beginner in Arduino so it would be better for me if there was something detailed)
I attach an example of the sound I need to create.
here is the link (attach option was not available)
I created this sound by Matklab.
Thanks a lot!
How does it compare with the loudness you can get with the tone played on a laptop?
5ms isn’t enough time for your brain to hear the “loudness”. Plus, your ear is most-sensitive at around 2kHz and as you go higher (or lower) you loose sensitivity. Maybe you’ve got some high-frequency hearing loss? (And of course, since you’re using a tweeter that doesn’t reproduce low frequencies.)
…A bigger amplifier or a more sensitive speaker will of course go louder.
No… It’s just “digital data” and you’d still need the DF player (or something) for D/A conversion and amplification.
…However, MP3 (lossy compression) will add silence to the beginning & end so the total file length will be a few milliseconds longer. (The sound will still be ~5ms). I can’t think of any good reason to be using lossy compression with such a short file.
