I am currently trying to write and read off a microSD card with Arduino Mega 2560 and a Adafruit CC3000 Wifi Shield. The shield was set up according to the Adafruit hookup guide, however no additional wirings were attached to the Mega.
I am using the code below, and have tried many other similar codes and cannot get the SD card to initialize (initialization failed appears in Serial Monitor). I am not sure if I have to connect something to pin 53 on the mega even though the SD card is routed through pin 4? I have attached a picture of the WIFIshield and Arduino for reference.
#define SD_CS_PIN SS
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
SdFat SD;
File myFile;
const int chipSelect = 4;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10,OUTPUT); // pin 10 must be left as an OUTPUT so it can be set HIGH
digitalWrite(10,HIGH); // pin 10 needs to be put HIGH to explicitly deselect the WiFi HDG104 chip[code]
if (!SD.begin(SD_CS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
