I tried play xlights fseq 576led matrix using code below. Designs are play but some designs play wrong direction and worng colors. i tried so much changing settings on xlights. i want to know is there any changes to do in this arduino programme.
#include <FastLED.h>
#include <SPI.h>
#include <SD.h>
#define NUM_LEDS 576
#define DATA_PIN 13
#define CHIPSET WS2812
#define CMD_NEW_DATA 1
#define BAUD_RATE 115200
File fxdata;
CRGB leds[NUM_LEDS];
FastLED.addLeds<CHIPSET, DATA_PIN>(leds, NUM_LEDS); //see doc for different LED strips
Serial.begin(BAUD_RATE);
for (int y = 0 ; y < NUM_LEDS ; y++)
leds[y] = CRGB::Black; // set all leds to black during setup
FastLED.show();
pinMode(53, OUTPUT); // CS/SS pin as output for SD library to work.
digitalWrite(10, HIGH); // workaround for sdcard failed error...
if (!SD.begin(10))
Serial.println("sdcard initialization failed!");
return;
Serial.println("sdcard initialization done.");
// test file open
fxdata = SD.open("xlights.fse"); // read only
if (fxdata)
Serial.println("file open ok");
fxdata.close();
int serial ()
while (!Serial.available()) {}
return Serial.read();
if (fxdata)
while (fxdata.available())
fxdata.readBytes((char*)leds, NUM_LEDS * 3);
FastLED.show();
delay(0); // set the speed of the animation. 20 is appx ~ 500k bauds
// close the file in order to prevent hanging IO or similar throughout time
fxdata.close();
}Preformatted text
