I was trying to light up 2 7-segment display using a 74hc595. I’m using common anodes 7-segment, so basically when i want to light up the segment i need to give low logic output to 74hc595… but i faced a very unexpected result. i can’t light up the segment with Low logic… but when i use a High logic the segment is light up… is this make sense?
if i give HIGH into the shift register output, i have +V at both ends of my circuit, and no current flows. is the 74hc595 inverting the logic that i give?
this is the schematic
//This is the hex value of each number stored in an array by index num [G,F,E,D,C,B,A], [0,1,2,3,4,5,6,7,8,9]
byte digitOne[10]= {0b10111111, 0b00000110, 0b11011011, 0b11001111, 0b11100110, 0b11101101, 0b11111101, 0b00000111, 0b11111111, 0b11101111,};
byte digitTwo[10]= {0b10111111, 0b00000110, 0b11011011, 0b11001111, 0b11100110, 0b11101101, 0b11111101, 0b00000111, 0b11111111, 0b11101111,};
digitalWrite(LATCH, LOW);
shiftOut(DATA, CLK, MSBFIRST, ~digitTwo*); // digitTwo*
shiftOut(DATA, CLK, MSBFIRST, ~digitOne[j]); // digitOne
digitalWrite(LATCH, HIGH);
