I have Arduino mega2560 , esp8266 and 8 channel relay
I want to make operating 8 channel relay with my android mobile through esp8266 please help to create program code
or please give me source code for it I m tired searching lots of websites but still I didn't get any solution hope u all reply as soon as possible.
You first. Post your program and tell us what it does. Then explain what you want it to do.
THIS PROGRAM FOR ARDUINO UNO CAN U CONVERT IT FOR MEGA2560 ACTUALLY I WANT TO MAKE ON OFF 8 CHANNEL RELAY WITH TCP CLIENT THROUGH ESP8266 ESP01 SO PLEASE DO NEEDFUL
ESP8266 library
Connection:
When you use it with UNO board, the connection should be like these:
ESP8266_TX->RX(D10)
ESP8266_RX->TX(D11)
ESP8266_CH_PD->3.3V
ESP8266_VCC->3.3V
ESP8266_GND->GND
When you want to output the debug information, please use DebugSerial. For example,
DebugSerial.println("hello");
Note: The size of message from ESP8266 is too big for arduino sometimes, so the library can't receive the whole buffer because
the size of the hardware serial buffer which is defined in HardwareSerial.h is too small.
Open the file from \arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.h.
See the follow line in the HardwareSerial.h file.
#define SERIAL_BUFFER_SIZE 64
The default size of the buffer is 64. Change it into a bigger number, like 256 or more.
//#define SSID "dlink"
//#define PASSWORD "0814931872"
#define SSID "SmartHome"
#define PASSWORD "0816452400"
#include "uartWIFIUNO.h"
#include <SoftwareSerial.h>
WIFIUNO wifi;
extern int chlID;
// set pin numbers:
const int ledPin = 13; // the number of the LED pin
const int relay1 = 2;
const int relay2 = 3;
const int relay3 = 4;
const int relay4 = 5;
boolean device1 = false;
boolean device2 = false;
boolean device3 = false;
boolean device4 = false;
void setup(){
pinMode(ledPin, OUTPUT);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
//pinMode(ESP8266_CHPD, OUTPUT);
//digitalWrite(ESP8266_CHPD,LOW);
digitalWrite(relay1,LOW);
digitalWrite(relay2,LOW);
digitalWrite(relay3,LOW);
digitalWrite(relay4,LOW);
DebugSerial.println("ESP8266 Server v0.21");
if(!wifi.begin())
DebugSerial.println("Begin error");
bool b = wifi.Initialize(STA, SSID, PASSWORD);
if(!b)
DebugSerial.println("Init error");
delay(8000); //make sure the module can have enough time to get an IP address
String ipstring = wifi.showIP();
DebugSerial.println(ipstring); //show the ip address of module
wifi.confMux(1);
delay(100);
if(wifi.confServer(1,80))
DebugSerial.println("Server is set up");
char buf[500];
int iLen = wifi.ReceiveMessage(buf);
if(iLen > 0)
DebugSerial.print(buf);
//delay(300);
if (strncmp(buf, "GET /?status1=1", 15) == 0) {
//DebugSerial.print("RELAY 1 ON");
digitalWrite(relay1, HIGH);
device1 = true;
else if (strncmp(buf, "GET /?status1=0", 15) == 0) {
//DebugSerial.print("RELAY 1 OFF");
digitalWrite(relay1, LOW);
device1 = false;
if (strncmp(buf, "GET /?status2=1", 15) == 0) {
//DebugSerial.print("RELAY 2 ON");
digitalWrite(relay2, HIGH);
device2 = true;
else if (strncmp(buf, "GET /?status2=0", 15) == 0) {
//DebugSerial.print("RELAY 2 OFF");
digitalWrite(relay2, LOW);
device2 = false;
String cmd;
cmd = "HTTP/1.1 200 OK\r\n";
cmd += "Content-Type: text/html\r\n";
cmd += "Connection: close\r\n";
//cmd += "Refresh: 15\r\n";
cmd += "\r\n";
//cmd += "\r\n";
cmd += "\r\n";
//cmd += "ESP8266 Webserver
"ESP8266 Web Server Control"
";if(device1){
cmd +=("
Device1 : ON");
else{
cmd +=("
Device1 : OFF");
if(device2){
cmd +=("
Device2 : ON");
else{
cmd +=("
Device2 : OFF");
if(device3){
cmd +=("
Device3 : ON");
else{
cmd +=("
Device3 : OFF");
if(device4){
cmd +=("
Device4 : ON");
else{
cmd +=("
Device4 : OFF");
cmd += "\r\n";
wifi.Send(chlID,cmd);
//delay(200);
wifi.closeMux(chlID);
//delay(1000);
