Hi, i am a beginner. I have a problem, arduino sometimes stops working (he just gets stuck) after the "If" function, (part of the code is marked in yellow).
Help me, Where is the problem?
THANK YOU,
//#define BLYNK_PRINT Serial
#include <SPI.h>
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h>
char auth = “**************”;
#define W5100_CS 10
#define SDCARD_CS 4
#define BLYNK_RED “#D3435C”
#define BLYNK_GREEN “#23C48E”
BlynkTimer timer;
#include <Wire.h>
#include “RTClib.h”
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
RTC_DS1307 rtc;
int SR = (A9);
int MR = (A8);
int NR = (A10);
int MM = (A11);
boolean dopen = true;
boolean dclose = true;
int inpu1 = 22;
int inpu2 = 23;
int inpu3 = 24;
int inpu4 = 25;
int inpu5 = 26;
int inpu6 = 27;
//int bdoor = 0;
const int reverse = 30;
const int door = 31;
const int window = 32;
const int watering = 33;
const int wout = 34;
char daysOfTheWeek[7][12] = {“Sunday”,“Monday”, “Tuesday”, “Wednesday”, “Thursday”, “Friday”, “Saturday”};
void myTimerEvent()
// You can send any value at any time.
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V5, millis() / 100);
void setup () {
pinMode(SDCARD_CS, OUTPUT); //blynk
digitalWrite(SDCARD_CS, HIGH);
Blynk.begin(auth);
timer.setInterval(1000L, myTimerEvent);
pinMode(reverse ,OUTPUT);
pinMode(door ,OUTPUT);
pinMode(window ,OUTPUT);
pinMode(watering ,OUTPUT);
pinMode(wout, OUTPUT);
pinMode(inpu1,INPUT_PULLUP);
pinMode(inpu2,INPUT_PULLUP);
pinMode(inpu3,INPUT);
pinMode(inpu4,INPUT);
pinMode(inpu5, INPUT);
pinMode(inpu6, INPUT);
if (! rtc.begin()) {
Serial.println(“Couldn’t find RTC”);
while (1);
if (! rtc.isrunning()) {
Serial.println(“RTC is NOT running!”);
// following line sets the RTC to the date & time this sketch was compiled
//rtc.adjust(DateTime(F(DATE), F(TIME)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2020, 04, 28, 21, 23, 0)); // <----------------------SET TIME AND DATE: YYYY,MM,DD,HH,MM,SS
delay(100);
lcd.begin(16,2);
rtc.adjust(DateTime(2020, 05, 3, 23, 30, 5)); // <----------------------SET TIME AND DATE: YYYY,MM,DD,HH,MM,SS
//BLYNK_WRITE(V4)
//bdoor = param.asInt();
// if (param.asInt()== 1){
//bdoor == HIGH;
// } else { bdoor == LOW;
void loop () {
int dig = digitalRead(inpu1);
int dig1 = digitalRead(inpu2);
int dig2 = digitalRead(inpu3);
int dig3 = digitalRead(inpu4);
int dig4 = digitalRead(inpu5);
int dig5 = digitalRead(inpu6);
Blynk.run();
if (dig==HIGH)
Blynk.virtualWrite(V11,255);
Blynk.setProperty(V11, “color”, BLYNK_GREEN);
Blynk.setProperty(V11, “label”, “DOOR IS OPEN”);
if (dig1==HIGH)
Blynk.setProperty(V11, “color”, BLYNK_RED);
Blynk.setProperty(V11, “label”, “DOOR IS CLOSE”);
if ((dig==LOW) && (dig1==LOW))
Blynk.virtualWrite(V11,0);
Blynk.setProperty(V11, “label”, “RUNING”);
if (dig2==HIGH)
Blynk.virtualWrite(V12,255);
Blynk.setProperty(V12, “color”, BLYNK_GREEN);
Blynk.setProperty(V12, “label”, “WINDOW IS OPEN”);
if (dig3==HIGH) {
Blynk.setProperty(V12, “color”, BLYNK_RED);
Blynk.setProperty(V12, “label”, “WINDOW IS CLOSE”);
if ((dig3==LOW) && (dig2==LOW))
Blynk.virtualWrite(V12,0);
Blynk.setProperty(V12, “label”, “RUNING”);
if (dig4==LOW)
Blynk.virtualWrite(V13,255);
Blynk.setProperty(V13, “color”, BLYNK_GREEN);
Blynk.setProperty(V13, “label”, “WATERING INSIDE ON”);
{ (dig4==HIGH);
Blynk.virtualWrite(V13,0);
Blynk.setProperty(V13, “label”, "WATERING INSIDE OFF ");
if (dig5==LOW)
Blynk.virtualWrite(V14,255);
Blynk.setProperty(V14, “color”, BLYNK_GREEN);
Blynk.setProperty(V14, “label”, “WATERING OUTSIDE ON”);
{ (dig5==HIGH);
Blynk.virtualWrite(V14,0);
Blynk.setProperty(V14, “label”, “WATERING OUTSIDE OFF”);
if ( (dig == HIGH) && (dig2 == HIGH)) {
digitalWrite(reverse, HIGH);
if ( (dig1 == HIGH) && (dig3 == HIGH)) {
digitalWrite(reverse, LOW);
digitalWrite(wout, HIGH);
DateTime now = rtc.now();
Serial.print(now.day(), DEC);
Serial.print(’/’);
Serial.print(now.month(), DEC);
Serial.print(’/’);
Serial.print(now.year(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(’:’);
Serial.print(now.minute(), DEC);
Serial.print(’:’);
Serial.print(now.second(), DEC);
delay(200); //Print date and time every 1 sec
lcd.setCursor(0, 0);
lcd.print(now.year(), DEC);
lcd.print(’/’);
lcd.print(now.month(), DEC);
lcd.print (’/’);
lcd.print(now.day(), DEC);
lcd.setCursor(0, 1);
lcd.print(now.hour(), DEC);
lcd.print(’:’);
lcd.print(now.minute(), DEC);
lcd.print(’:’);
lcd.print(now.second(), DEC);
int atidaryti = (now.hour() == 7 && now.minute() == 5 && now.second() == 5);
int uzdaryti = (now.hour() == 22 && now.minute() == 21 && now.second() == 30 );
if ((dopen == true)||(dclose == true)) {
digitalWrite(door, LOW);
digitalWrite(window, LOW);
else {
digitalWrite(door, HIGH);
digitalWrite(window, HIGH);
if (now.hour() >= 21 && now.minute() >= 49) {
digitalWrite(wout, LOW);
if (now.hour() >= 21 && now.minute() >= 50 ) {
int NR = analogRead(A10); // Agurkai vidus
int SR = analogRead(A9); // Ridikai, salotos
int MR = analogRead(A8); // Laukas
int MM = analogRead(A11); // Vandens lygis
SR = map(SR, 650, 340, 0,100); // Ridikai, salotos
SR = constrain(SR, 0, 100);
MR = map(MR, 650, 340, 0,100); // Laukas
MR = constrain(MR, 0, 100);
NR = map(NR, 650, 340, 0,100); // Agurkai vidus
NR = constrain(NR, 0, 100);
MM = map(MM, 86, 36, 0,100); // Agurkai vidus
//int vala= analogRead(A9);
//SR = map(vala, 340, 650, 100, 0);
lcd.setCursor(12,1);
lcd.println(SR);
lcd.setCursor(15,1);
lcd.println(’%’);
Blynk.virtualWrite(V20, SR); // blynk Ridikai, salotos
Blynk.virtualWrite(V21, MR); // Laukas
Blynk.virtualWrite(V22, NR); // Agurkai vidus
Blynk.virtualWrite(V23, MM); // Vandens lygis
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor. The text editor shows line numbers, identifies matching brackets and allows me to search for things like all instances of a particular variable or function.
Also please use the AutoFormat tool to indent your code consistently for easier reading.
...R
#include <SPI.h>
char auth[] = "**************";
#define W5100_CS 10
#define SDCARD_CS 4
#define BLYNK_RED "#D3435C"
#define BLYNK_GREEN "#23C48E"
BlynkTimer timer;
#include <Wire.h>
#include "RTClib.h"
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
RTC_DS1307 rtc;
int SR = (A9);
int MR = (A8);
int NR = (A10);
int MM = (A11);
int inpu1 = 22;
int inpu2 = 23;
int inpu3 = 24;
int inpu4 = 25;
int inpu5 = 26;
int inpu6 = 27;
//int bdoor = 0;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void myTimerEvent()
// Please don't send more that 10 values per second.
void setup () {
Blynk.begin(auth);
pinMode(reverse , OUTPUT);
pinMode(door , OUTPUT);
pinMode(window , OUTPUT);
pinMode(watering , OUTPUT);
pinMode(inpu1, INPUT_PULLUP);
pinMode(inpu2, INPUT_PULLUP);
pinMode(inpu3, INPUT);
pinMode(inpu4, INPUT);
Serial.println("Couldn't find RTC");
while (1);
Serial.println("RTC is NOT running!");
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
delay(100);
lcd.begin(16, 2);
//BLYNK_WRITE(V4)
//bdoor == HIGH;
void loop () {
Blynk.run();
if (dig == HIGH)
Blynk.virtualWrite(V11, 255);
Blynk.setProperty(V11, "color", BLYNK_GREEN);
Blynk.setProperty(V11, "label", "DOOR IS OPEN");
if (dig1 == HIGH)
Blynk.setProperty(V11, "color", BLYNK_RED);
Blynk.setProperty(V11, "label", "DOOR IS CLOSE");
if ((dig == LOW) && (dig1 == LOW))
Blynk.virtualWrite(V11, 0);
Blynk.setProperty(V11, "label", "RUNING");
if (dig2 == HIGH)
Blynk.virtualWrite(V12, 255);
Blynk.setProperty(V12, "color", BLYNK_GREEN);
Blynk.setProperty(V12, "label", "WINDOW IS OPEN");
if (dig3 == HIGH) {
Blynk.setProperty(V12, "color", BLYNK_RED);
Blynk.setProperty(V12, "label", "WINDOW IS CLOSE");
if ((dig3 == LOW) && (dig2 == LOW))
Blynk.virtualWrite(V12, 0);
Blynk.setProperty(V12, "label", "RUNING");
if (dig4 == LOW)
Blynk.virtualWrite(V13, 255);
Blynk.setProperty(V13, "color", BLYNK_GREEN);
Blynk.setProperty(V13, "label", "WATERING INSIDE ON");
{ (dig4 == HIGH);
Blynk.virtualWrite(V13, 0);
Blynk.setProperty(V13, "label", "WATERING INSIDE OFF ");
if (dig5 == LOW)
Blynk.virtualWrite(V14, 255);
Blynk.setProperty(V14, "color", BLYNK_GREEN);
Blynk.setProperty(V14, "label", "WATERING OUTSIDE ON");
{ (dig5 == HIGH);
Blynk.virtualWrite(V14, 0);
Blynk.setProperty(V14, "label", "WATERING OUTSIDE OFF");
Serial.print('/');
Serial.print('/');
Serial.print(" (");
Serial.print(") ");
Serial.print(':');
Serial.print(':');
lcd.print('/');
lcd.print ('/');
lcd.print(':');
lcd.print(':');
int dopen = (now.hour() == 7 && now.minute() == 5 && now.second() == 5);
int dclose = (now.hour() == 22 && now.minute() == 21 && now.second() == 30 );
if ((dopen == true) || (dclose == true)) {
else {
SR = map(SR, 650, 340, 0, 100); // Ridikai, salotos
MR = map(MR, 650, 340, 0, 100); // Laukas
NR = map(NR, 650, 340, 0, 100); // Agurkai vidus
MM = map(MM, 86, 36, 0, 100); // Agurkai vidus
lcd.setCursor(12, 1);
lcd.println(SR);
lcd.setCursor(15, 1);
lcd.println('%');
problem is when running function " if ((dopen == true) || (dclose == true)) {
You seem to have defined dopen twice
and
Try removing the "int" from the line
...R
So, twice a day (but just for one second), one of these variables will be true and 'door' and 'window' will be set low for only one second... is that what you want? I doubt it.
else {
I need to give a pulse of one second for opening and a pulse of one second for closing
