I've been making a flight computer for a rocket I'd like to include a gps logger. I've found the attached script. It compiles fine, but only leaves 95 bytes for local variables. I've already moved most of the string out puts to flash memory. My problem/question is will the leftover memory be enough for local variables. If not, then is there a way I, a beginner, can further realistically optimize the memory usage so I have enough memory for local variables?
Sorry if my syntax or terminology is bad, I'm very much out of my element. Thank you for the help.
edit: Sorry here is the code posted correctly after using auto format
#include "SPI.h"
#include <SD.h>
#include "Adafruit_GPS.h"
#include "SoftwareSerial.h"
#define convLong()
#define convLati()
SoftwareSerial mySerial(3, 2);
Adafruit_GPS GPS(&mySerial);
String NMEA1;
String NMEA2;
char c;
float deg;
float degWhole;
float degDec;
int chipSelect = 4;
File mySensorData;
void readGPS() {
clearGPS();
while (!GPS.newNMEAreceived()) {
c = GPS.read();
GPS.parse(GPS.lastNMEA());
NMEA1 = GPS.lastNMEA();
c = GPS.read();
NMEA2 = GPS.lastNMEA();
Serial.println(NMEA1);
Serial.println(NMEA2);
void clearGPS() {
c = GPS.read();
c = GPS.read();
} // while(!GPS.newNMEAreceived()) {
c=GPS.read();
c = GPS.read();
GPS.begin(9600);
//Send commands to the GPS module
GPS.sendCommand("$PGCMD,33,0*6D");
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
//only if your SD module's CS pin isn't on pin D10
pinMode(10, OUTPUT);
SD.begin(chipSelect);
readGPS();
if (SD.exists("NMEA.txt")) {
mySensorData = SD.open("NMEA.txt", FILE_WRITE);
mySensorData.println(F("<----------------------- New session ----------------------->"));
mySensorData.print(F("*** "));
mySensorData.print(GPS.day);
mySensorData.print(F("."));
mySensorData.print(GPS.month);
mySensorData.print(GPS.year);
mySensorData.print(F(" -- "));
mySensorData.print(GPS.hour);
mySensorData.print(F(":"));
mySensorData.print(GPS.minute);
mySensorData.print(GPS.seconds);
mySensorData.println(F(" ***"));
mySensorData.close();
readGPS();
// Condizione if che controlla se l'antenna ha segnale. Se si, procede con la scrittura dei dati.
if (GPS.fix == 1) { //Only save data if we have a fix
mySensorData = SD.open("NMEA.txt", FILE_WRITE); //Apre il file per le frasi NMEA grezze
mySensorData.println(NMEA1); //Scrive prima NMEA sul file
mySensorData.println(NMEA2); //Scrive seconda NMEA sul file
mySensorData.close(); //Chiude file!!
mySensorData = SD.open("GPSData.txt", FILE_WRITE);
// Converte e scrive la longitudine
convLong();
mySensorData.print(deg, 4); // Scrive le coordinate in gradi sul file
mySensorData.print(F(",")); // Scrive una virgola per separare i dati
Serial.print(deg);
Serial.print(F(","));
// Converte e scrive la latitudine
convLati();
Serial.print(deg);
// Scrive l'altitudine
mySensorData.print(GPS.altitude);
mySensorData.print(F(" "));
Serial.println(GPS.altitude);
gpslogger2.ino (3.85 KB)
