Hi Guys,
I think this should be an easy thing but I’m designing a menu system that I can use for a timelapse motion slider. There is people that have done this before but I’m doing it for a school project and I wanted to do as much of the coding myself as I could.
I’m using a standard 12mm rotary encoder from eBay and a rotary encoder library from:
https://www.pjrc.com/teensy/td_libs_Encoder.html
(I tried doing the code for this myself but it didn’t work)
Here is my code:
/* The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 9
* LCD D7 pin to digital pin 8
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
#include <Encoder.h>
int encoderVal = 0;
int menuVal = 0;
int NumToShow = 0;
int resetVal = 0; //value to reset encoder to
int buttonVal = 0;
int lastMenu = 0; //val to store menu value
Encoder myEnc(2, 3);
int buttonPin = 7;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 9, 8);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
digitalWrite (buttonPin, HIGH); //pullup internal pullup resistor
long oldPosition = -999;
long newPosition = myEnc.read();
if (newPosition != oldPosition) { //this reads the rotary encoder
oldPosition = newPosition;
encoderVal = newPosition/4; //without this the encoder gives a 4,8,12,16 etc value instead of a 1,2,3,4 value
menuVal = encoderVal;
NumToShow =encoderVal;
buttonVal = digitalRead (buttonPin);
if (menuVal >= 3 || menuVal < 0) { //This means that the menuVal is never greater than 3 or less than 0 as there are only 4 menu options
myEnc.write (resetVal);
switch (menuVal) {
case 0:
lcd.setCursor (0,0);
lcd.print("Main Menu: ");
lcd.setCursor (0,1);
lcd.print ("Turn For Option");
case 1:
lcd.print ("Option 1 ");
lcd.print (" Num: 0 ");
if (buttonVal == LOW) { //Here is the part I'm having trouble with:
lastMenu = 1;
menuVal = lastMenu;
lcd.print (" Num: ");
lcd.print (NumToShow);
if (buttonVal == LOW && lastMenu == 1) {
myEnc.write (lastMenu);
} //What I want it to do is store the last menuVal keep it in this case but change another variable 'NumToShow' with
//the rotary encoder.
case 2:
lcd.print ("Option 2 ");
} //this bottom one will be added in once I get the base program in case 1 working
My aim is to design a menu system using one rotary encoder with a built in pushbutton.
I want to read the encoder, give first a menu value between 0-3, when the pushbutton is pressed I want to store that last menuVal to keep the menu on that option. I then want to change a separate value using the rotary encoder by firstly resetting the encoderVal back to 0 and then printing that value next to Num: .
What its currently doing is correct for the code but not what I want it to do, it goes through the menu options starting with option 0 (Main Menu) when its is on option 1 I press the button and the menu resets to option 0 where I want it to save a value and remain on option 1 while changing a separate value which is then lcd.print ed.
I’m sorry if any of this doesn’t make sense! I was just trying to right my thoughts/plans out.
Thanks for any help,
Nathan
