Im using :
Arduino Uno R3 Compatible
RFID Rc522 Card reader detector
It happen when i try to upload or verify code into rfid_read_personal_data
In file included from C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:8:0:
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h: In constructor 'MFRC522Extended::MFRC522Extended(uint8_t)':
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:81:44: warning: 'MFRC522::MFRC522(byte)' is deprecated: use MFRC522(byte chipSelectPin, byte resetPowerDownPin) [-Wdeprecated-declarations]
MFRC522Extended(uint8_t rst) : MFRC522(rst) {};
In file included from C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.h:10:0,
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.h:335:2: note: declared here
MFRC522(byte resetPowerDownPin);
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_SetUid(byte*, byte, bool)':
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1818:7: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
if (!MIFARE_OpenUidBackdoor(logErrors)) {
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1674:6: note: declared here
bool MFRC522::MIFARE_OpenUidBackdoor(bool logErrors) {
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1818:39: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp: In member function 'bool MFRC522::MIFARE_UnbrickUidSector(bool)':
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1847:2: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
MIFARE_OpenUidBackdoor(logErrors);
C:\Users\Shahidan\Documents\Arduino\libraries\MFRC522\src\MFRC522.cpp:1847:34: warning: 'bool MFRC522::MIFARE_OpenUidBackdoor(bool)' is deprecated: will move to extra class in next version [-Wdeprecated-declarations]
Sketch uses 6542 bytes (20%) of program storage space. Maximum is 32256 bytes.
Global variables use 281 bytes (13%) of dynamic memory, leaving 1767 bytes for local variables. Maximum is 2048 bytes.
