i have done that now i get this error:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0xdf != 0xff
avrdude: verification error; content mismatch
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
Pity that You dont have any other ISP programmer that could work with Atmel Studio.
I am working on project with Attiny 25 20PU and when i started i found out that some of my Attinys were bricked up from past when i had absoultely no idea how to program and so.
So to test if the atmel is ok, i am using ZeptoProg programmer which works with Atmel Studio and there, if You can read device infos, the chip itself is okay. Then You must work around with the wiring.
The previously mentioned capacitor is must have, at least for me, without it, the upload did not work.
I had 100uF so i used that one instead of 10uF.
How do You upload it? I am using "Upload Using Programmer Ctrl+Shift+U" option from "File" menu.
Dont forget to specify COM port where the Arduino as ISP is connected and also that You are using Arduino as ISP
