Hi all,
I am trying to upload my code that I used on my arduino uno to my arduino micro.
I am using a Kindle cable that fits in the micro USB porr on the Aruio micro. That shouldn't be a problem right?
I am getting this error message. How do I get it to upload?
Sketch uses 12,112 bytes (42%) of program storage space. Maximum is 28,672 bytes.
Global variables use 611 bytes (23%) of dynamic memory, leaving 1,949 bytes for local variables. Maximum is 2,560 bytes.
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:130)
at processing.app.debug.Compiler.upload(Compiler.java:157)
at processing.app.Sketch.upload(Sketch.java:1259)
at processing.app.Sketch.exportApplet(Sketch.java:1201)
at processing.app.Sketch.exportApplet(Sketch.java:1173)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2466)
at java.lang.Thread.run(Thread.java:745)
Caused by: processing.app.SerialException: Error touching serial port 'COM1'.
at processing.app.Serial.touchPort(Serial.java:91)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:119)
... 6 more
Caused by: jssc.SerialPortException: Port name - COM1; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.touchPort(Serial.java:86)
... 7 more
Thanks,
Andrew >
