arduino micro digital pins
I am a total noob so bare with me please. i just purchased an arduino micro and would like to use 15 digital pins as sensor I/O. The product page says that is has 20 digital I/O's but when i look at the pinouts it only lists pins 0-13 (assuming that i can use the TX and RX as digital pins 0 and 1). so what pins are the other digital pins? and can i define them like i would normally, like as in pin 14? or can i even define 15 digital I/O's on the Micro? any information helps. thanks!
The “analog” pins work for digital I/O as well.
Yes, A0 to A5 can be called out as D14-D19.
oh, ok. so in the sketch do i define it as D14 or just 14
EXAMPLE:
define LED D14
or
define LED 14
Thanks
Wolven1992:
EXAMPLE:
#define LED D14
or
#define LED 14
Thanks
Neither. Use “A0”, “A1”…etc
@fingus, Why would you use
define LED A0
vs
define LED 14
CrossRoads: @fingus, Why would you use
define LED A0
vs
define LED 14
Because that's what's printed on the PCB.
Would you know where pin "14" was just by looking at an Arduino Uno?
