Arduino Micro, Need 16-bit PWM capability. >>>>
I have a AMicro here that I'm trying to setup one of the PWM outputs to use a 16-bit resolution. From what I am reading, it appears that this can be done, however, what I have come across in several hours of searching hasn't turned up any good news.
I am wanting to use this with an Res/Cap circuit to create an analog voltage output, 0-~5V. 12-bit resolution would work for my application but 16-bit would match the system it is connecting into.
Also, where is the SEARCH function for this forum?? There is a search at the top right of these pages but that is a web search, not a forum-only search.
Thanks!
AshPowers:
Have you tried the "TimerOne" or "TimerThree" libraries? Or are you wanting to do this at the register level yourself?
AshPowers:
It is a forum only search "powered by Google". I'm not fussed either, but it should do what you want.
https://www.arduinoslovakia.eu/blog/2017/7/16-bitove-rozlisenie-pwm-pre-arduino?lang=en
arduarn:
Thanks!
Look closer at the results.
