Arduino micro - stops working using an empty class (ide v 1.8.9)
Hello
I was busy working on a project (containing many classes) when suddently the arduino became unresponsive
I simplified the project to figure what was causing this
basicaly, one empty C++ class is added to the project
from the moment that class is instanciated staticaly or simply declared as a pointer, the arduino - once programmed - disappear as an usb device
I have to reset it to program it again, here is the main code :
#include "main.h"
Main* main; // this crashes the arduino
//Main main; // this too
int led = 13; // simple test code from examples
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
here is the culprit class :
#ifndef MAIN_H
#define MAIN_H
class Main
public:
  Main();
#endif
and its implementation :
#include "main.h"
Main::Main()
I tried renaming the class too, just in case of conflict
I thought my arduino was fried, I tried with another one, same thing
I use sublime text, I noticed the arduino ide was sometimes out of wack, so I had to restart it
this makes no sens at all
can someone confirm this ? anything wrong with the code ? I feel I miss something really obvious, but I double checked everything
regards
apparently, while renaming the class to Main2 (the cpp and h files too) did not work,
renaming the class as systemCore did work
I really dont have any logical explanation for this on , since the compiler does not complain at all
this is quiet insane from an engineer point of you, I mean come on !!!
I guess the system gets confused because there is already a main() function in every C/C++ program; so you can't have a variable of type Main called main.
I can't check at this moment if the compiler throws warnings if you set the warning level to all. What us your warning level set to in file -> preferences?
