Arduino Micro + Waterrot mSD Breakout
Hi everyone,
For my project I use Arduino Micro and Watterott mSD Breakout Board (http://www.watterott.com/en/mSD-Breakout)
I have connected
Vcc → 3V
Gnd → Gnd
CLK → 13
D0 → 12
DI → 11
CS → 10
When I run Example SD-> CardInfo initalization fails.
Anyone has any idea what might be wrong?
Thanks in advance.
Best regards,
Have you set the CS pin in the CardInfo sktech to pin 10?
const int chipSelect = 10;
The breakout has an onboard voltage regulator. So you can connect 5V from the Arduino to 5V from the breakout.
Rgds
Andreas
Hi, thanks for reply.
Yes, I changed that. Forgot to mention that before. And on 3.3 V I have also connected AXL335 breakout also bought at Watterott. Could that be a problem?
Is there anything else I might forgot?
Best regards,
I have not seen that you are using an Arduino Micro (with ATmega32U4).
On this you have to connect:
CLK -> SCK (first pin next to ICSP connector)
D0 -> MISO (second pin next to ICSP connector)
DI -> MOSI (first pin next to RST switch)
CS -> D10
Rgds,
Andreas
