I have trouble to make work an arduino micro with a Wiz850IO.
It Work with a UNO, but something wrong when i make it with the Mirco... I have try both the SPI pin on the top of the card and the side (board) pin.
my connection are :
Micro --------- Wiz850
Gnd -------------- Gnd
3v -------------- V
MISO ------------ MISO
SCK ------------SCK
MOSI ---------- MOSI
SS ------------- CS
I'm a bit confused about the CS Pin number and used Ethernet.init(8); to declare it.
what do I do wrong !?
Thanks for your help
F
my code is :
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <OSCMessage.h>
#include <OSCBoards.h>
#include <OSCBundle.h>
#include <Servo.h>
byte mac[] = { 0xDE, 0xAF, 0xBD, 0xEA, 0xEE, 0xED };
IPAddress ip(192, 168, 1, 97); //ip of the arduino / ip to send On // change it on new card
unsigned int InPort = 8888; // port to send on
const unsigned int outPort= 9000; // computer port
EthernetUDP Udp; // An EthernetUDP instance to let us send and receive packets over UDP
Servo myServo_1, myServo_2; // create servo object to control a servo
int Valve = 2;
//================================================================ SETUP =================================
Ethernet.init(8); // config CS pin
pinMode(8, OUTPUT);
pinMode(Valve, OUTPUT);
myServo_1.attach(3);
myServo_2.attach(4);
delay(100);
myServo_1.write(137);
myServo_2.write(65);
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
Udp.begin(InPort);
Serial.print("hello world");
// ============================================================== OSC ====================================
// ========================= Ping =========================== //
void OSCMess_Ping(OSCMessage &msg, int addrOffset ){
OSCBundle bndl; //declare the bundle
if (msg.isInt(0)){
bndl.add("/System_Is_connect");
Udp.beginPacket(Udp.remoteIP(), outPort); // UDP Call/Response: Report on Ip directory
bndl.send(Udp); // send the bundle...
Udp.endPacket(); // mark the end of the OSC Packet
bndl.empty(); // clear the bundle, ready to use for new messages
void manageOSCMess_Valve(OSCMessage &msg, int addrOffset ){
if (msg.isInt(0)){
if(msg.getInt(0) == 1){
digitalWrite(Valve, HIGH);
else{
digitalWrite(Valve, LOW);
void manageOSCMess_Servo_1(OSCMessage &msg, int addrOffset ){
if (msg.isInt(0)){
myServo_1.write(msg.getInt(0));
Serial.println(msg.getInt(0));
void manageOSCMess_Servo_2(OSCMessage &msg, int addrOffset ){
if (msg.isInt(0)){
myServo_2.write(msg.getInt(0));
// ============================================================== LOOP ====================================
OSCMessage messageIN;
int size;
if((size = Udp.parsePacket())>0){
while(size--){
messageIN.fill(Udp.read());
if(!messageIN.hasError()) {
messageIN.route("/Valve", manageOSCMess_Valve);
messageIN.route("/Servo_1", manageOSCMess_Servo_1);
messageIN.route("/Servo_2", manageOSCMess_Servo_2);
messageIN.route("/Ping",OSCMess_Ping);
I've try both: The ICSP on top and the side pin write MI/SCK/MO/SS
I spend some time again today connect on the ICSP header pin and still nothing.
If I run exemple LinkStatus I get on the Serial Monitor= LinkStatus : unknow
If I run exemple file UDPNtpClient :
Failed to configure ethernet using DHCP
Ethernet shield was not found. sorry, can't run wihtout hardware
I try 2 different Wiz850 and get the same result...
I also test Them with a Teensy LC laying around and everything work at 1st try...
Do I need to configure the CS pin as output same if I use ethernet.init(x) ?
Does the pin mark SS on the board is pin 8 ? still confused about that !
/* W5500 Ethernet Web Server using DHCP - if it fails static IP address
using the Ethernet library ran File>Examples>Ethernet>WebServer
A simple web server that shows the value of the analog input pins.
using an Arduino WIZnet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
// connections UNO, Feather 32u4, Due, MKRFOX
// W5500 CS UNO 10 SS 32u4 D10 10 MKR D5 setup with Ethernet.init()
// W5500 MI UNO 12 MISO 32u4 MISO 14 MKR MISO D10
// W5500 MO UNO 11 MOSI 32u4 MOSI 16 MKR MOSI D8
// W5500 SCK UNO 13 SCK 32u4 SCK 15 MKR SCK D9
// W5500 RST UNO RES not connected
// W5500 VCC UNO 3.3V 32u4 3.3V MKR 3.3V
// W5500 GND UNO GND 32u4 GND MKR GND
// W5500 INT not connected
// NOTES:
// DUE is similar to UNO except use SPI pins (not pins 11 12 13)
// says "Ethernet cable is not connected." but works OK - see fix in setup()
// ESP32 gives compile time errors
#include <SPI.h>
#include "Ethernet.h"
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// You can use Ethernet.init(pin) to configure the CS pin
//Ethernet.init(10); // Most Arduino shields - Feather 32u4
//Ethernet.init(5); // MKR ETH Shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit FeatherWing Ethernet
//Ethernet.init(5); // ESP32 with Adafruit FeatherWing Ethernet
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Ethernet WebServer Example");
// start the Ethernet connection:
// attempt to configure using DHCP if it fails static IP address
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Serial.println(" attempt to set static IP address"); // start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
delay(1000); // FIX: added to give DUE time to find the Ethernet cable
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// print your local IP address:
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an HTTP request ends with a blank line
bool currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the HTTP request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard HTTP response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
change the init to suit your configuration, e.g.
Ethernet.init(8);
if DHCP fails it attempts to set up a static IP address
