ARDUINO MICROCONTROLADORA BLUETOOTH
SIMBAD
MÓDULO BLUETOOTH PARA MICROCONTROLADOR, CELULAR, PC OU PALM
Frequency Band : 2.4GHz ISM
Sensitivity : -80 dBm or better
Standard : Bluetooth 2.0
Antenna : External
RF Power : 0~4dBm
Working Distance : about 10 meters
Specification version 1.2 and V2.0 EDR
Profile : SPP (AT)
SLAVE AND MASTER MODE.
MÓDULO SIMBAD - DÚVIDAS FREQUENTES
FUNCIONA COM ARDUINO ?
SIM, USE O TXD E RXD DELE.
COM QUE VELOCIDADE PODE SE COMUNICAR COM O MICROCONTROLADOR ?
9600 OU 19200 OU 38400 OU 57600 OU 115200. USE COMANDO “BAU”
PERMITE MUDAR O PINCODE TRADICIONAL (0000/1234) ?
SIM, COM O COMANDO “PNU”
POSSO ATRIBUIR NOME A ELE ?
SIM, COM O COMANDO “NAM”
PODE PROCURAR OUTROS MÓDULOS ?
SIM, COM O COMANDO “SIQ”
PODE SE CONECTAR COM O OUTRO MÓDULO ?
SIM
MANDA MENSAGENS DO STATUS DA CONEXÃO ?
SIM, POR EXEMPLO “CON”, “DSC”
PODE CONFIGURÁ-LO COMO MESTRE ?
SIM, COM O COMANDO “MST”
POSSO VER QUEM SE CONECTA A ELE ?
SIM, COM O COMANDO “GRN”
POSSO SABER O MAC DELE ?
SIM, COM O COMANDO “RLA”
AO LIGAR OU RESETAR MÓDULO, COMO POSSO VER SE ESTÁ FUNCIONANDO?
ELE MANDA A MENSAGEM "PON"
ELE PAREIA TAMBEM COM PC, MOBILE OU PALM ?
SIM, FOI TESTADO.
É CLASSE II ?
SIM, 10 MTS
TEM COMUNICAÇÃO SERIAL ?
SIM, DEFAULT É 9600,N,8,1; TTL 3.3V
TEM COMANDOS AT ?
SIM, PARA CADA COMANDO, UMA RESPOSTA.
TESTADO COM J2ME, PYTHON EMBARCADO E BLUESOLEIL?
SIM, COM SUCESSO (REQUER CONHECIMENTO DE J2ME E PYTHON)
AVISA QUANDO ALGUÉM ESTA CONECTADO OU DESCONECTADO A ELE ?
SIM, “CON” PARA CONECTADO E “DSC” PARA DESCONECTADO
RESET POR SOFTWARE E HARDWARE ?
SIM, POR SOFTWARE É O “RST”
PODE AUTORIZAR QUEM PODE PAREAR ?
SIM, OBRIGATÓRIO, ATRAVÉS DO COMANDO “AUT”
CONVERSA COM ARM, PIC, AVR ?
SIM.
QUAL A LISTA DE COMANDOS AT DO SIMBAD ?
SIQ (PROCURA MÓDULOS BLUETOOTH PRÓXIMOS)
EIQ (PARA A PROCURA DE MÓDULOS BLUETOOTH PRÓXIMOS)
PAR (ENTRA NO MODO DE PAREAMENTO)
CNP (SAI DO MODO DE PAREAMENTO)
PNU (INFORMAO PIN CODE)
CON (ESTABELECE UMA CONEXÃO COM O MÓDULO BLUETOOTH)
DSC (FINALIZA UMA CONEXÃO COM O MÓDULO BLUETOOTH)
RST (RESETA MÓDULO BLUETOOTH)
RPT (REPORTA O ESTADO ATUAL DO MÓDULO BLUETOOTH)
SND (HABILITA ENVIO DE DADOS)
END (DESABILITA ENVIO DE DADOS)
BAU (MUDA BAUD RATE ATUAL)
NAM (MUDA NOME DO MÓDULO BLUETOOTH)
GRN (PEGA O NOME DE QUEM SE CONECTOU NO MÓDULO BLUETOOTH)
RLA (PEGA MAC DO MÓDULO BLUETOOTH)
RLN (PEGA O NOME DO MÓDULO BLUETOOTH)
AUT (HABILITA PAREAMENTO)
SLP (ENTRA NO MODO SLEEP)
WKP (SAI DO MODO SLEEP)
POR QUE O NOME "SIMBAD" ?
(SIMPLE BLUETOOTH ADAPTER)
HÁ REGULADOR NA ALIMENTAÇÃO ?
SIM, UM LM317
ELE É SMD ?
O RÁDIO SIM,O MÓDULO QUE CONTÉM O REGULADOR E ANTENA, NÃO.
O QUE SÃO AQUELES PINOS ?
ESQUERDO DE CIMA PARA BAIXO: RESET, TXD,RXD
DIREITO DE CIMA PARA BAIXO: VCC, LED, GND
POSSO JOGAR 5V NO TXD, RXD E RESET ?
NÃO!, NECESSITA DE UM DIVISOR DE TENSÃO, POIS TRABALHA COM 3.3V
QUAL O TAMANHO DELE ?
30mmX28mm
POR QUE AO TENTAR PAREAR COM O MÓDULO, ALGUMAS VEZES ELE MANDA “RQP” ?
NESTE MOMENTO MANDE UM PINCODE PARA HOST E ASSIM SE OBTEM O PAREAMENTO, UTILIZE COMANDO “PNU”
AO TENTAR SE CONECTAR A ELE VIA MÓBILE, NÃO ACHA O SERVIÇO "SPP", O QUE PODE SER ?
VOCÊ AUTORIZOU O MÓBILE COM COMANDO "AUT" ? O PARÂMETRO PARA "AUT" DEVE SER O MAC DO MÓBILE.
O RESET É EM QUAL NÍVEL LÓGICO ?
SIM
COMO MANDO UM COMANDO PARA ELE ? POR EXEMPLO “RST”
AT#RST SEGUIDO DE CR E LF (BYTES 13 E 10)
OS COMANDOS DEVEM SEMPRE SEREM EM MAÍUSCULO ?
SIM
COMO ENCERRAR O ENVIO DE DADOS ?
AGUARDE 50ms E ENVIE AT#END. SE NÃO AGUARDAR OS 50ms, o AT#END É INTERPRETADO COMO UM DADO A SER ENVIADO.
PAREAR E CONEXÃO SÃO A MESMA COISA ?
PARA SE CONECTAR O PAREAMENTO DEVE SER FEITO ANTES.
O QUE SIGNIFICA “BLUETOOTH” ?
O nome Bluetooth foi escolhido em homenagem ao rei da Dinamarca Harald Blatand, que era conhecido como Harald Bluetooth. Esse apelido lhe foi dado por ele possuir uma coloração azulada em seus dentes. O apelido foi usado para esta tecnologia pelo fato de Harald Bluetooth ter ficado conhecido como unificador da Dinamarca, logo o significado de Bluetooth é unificação.
MSN: tcpipchip@hotmail.com
