Arduino Mid carrier MQTT
Hi, I have recently acquired a portenta mid carrier card, arduino portenta c33 and 4g pro module.
I have been able to make connections to thingspeak, read and send data over https.
Now I am trying to send the data directly to my own mqtt broker, but I cannot find a way to configure the sending since the Arduino cellular library does not reference MQTT. Thank you.
I have a similar challenge and want to use this setup to connect to Arduino cloud which also uses MQTT but can’t find any references.
Thanks for any support
Hi Luis. I am a newbie to arduino and was looking to built an IoT monitoring device via LTE cellular. I read up on arduino and arrived at the same solution of yours using portenta mid carrier card, portenta c33 and 4g pro module. May I shamelessly request if you would share your code with me? Thank you.
You can use this file as a reference for your project. In this file you have how to send the data to the mqtt server
Hi, I'm going to share with you a code that I'm using to read 3 soilwatch 10 sensors and 1 sht31 for ambient temperature and humidity. This sketch sends the data to my own EMQX server that I have mounted on a QNAP.
#include "ArduinoCellular.h"
#include <PubSubClient.h>
#include <Arduino.h>
#include "arduino_secrets.h"
#include <Wire.h>
#include "Adafruit_SHT31.h"
#include <ArduinoJson.h>
// Configuraciones MQTT
const char* mqtt_server = SECRET_SERVER_MQTT;
const char* mqtt_user = SECRET_USER_MQTT;
const char* mqtt_password = SECRET_PASSWORD_MQTT;
const int mqtt_port = atoi(SECRET_PORT_MQTT);
// Inicializar las instancias de ArduinoCellular y PubSubClient
ArduinoCellular cellular = ArduinoCellular();
TinyGsmClient netClient = cellular.getNetworkClient();  // Cliente de red básico
PubSubClient client(netClient); // Usar el cliente básico para PubSubClient
// Variables para la gestión de reconexión
const int max_reconnect_attempts = 5;  // Número máximo de intentos de reconexión
int reconnect_attempts = 0;            // Contador de intentos de reconexión
unsigned long lastReconnectAttempt = 0; // Marca de tiempo del último intento de reconexión
unsigned long reconnectionPause = 0;    // Marca de tiempo para esperar entre reconexiones
bool inPause = false;                   // Indicador de pausa en reconexión
// Intervalo de publicación (10 minutos en milisegundos)
const unsigned long publishInterval = 3 * 60 * 1000;
unsigned long lastMsg = 0;
Adafruit_SHT31 sht31 = Adafruit_SHT31();
// Sensor SHT31
float HumedadSemillero;          // Variable para almacenar la humedad ambiente
float TemperaturaSemillero;      // Variable para almacenar la temperatura ambiente exterior.
int moistureValue1, mappedValue1;
int moistureValue2, mappedValue2;
int moistureValue3, mappedValue3;
int8_t HoraReferencia;     // Almacenamos la hora actual.
int8_t MinutosReferencia;  // Almacenamos los minutos.
int8_t SegundosReferencia; // Almacenamos los segundos.
const int Ventilador = 31;
//const int EstadoVentilador = 32;
const int analogInPin1 = A1;      // Analog input pin that the sensor output is attached to (white wire)
const int analogInPin2 = A2;      // Analog input pin that the sensor output is attached to (white wire)
const int analogInPin3 = A3;      // Analog input pin that the sensor output is attached to (white wire)
int InversorEstado = 0;
//int ControlVentilador = 0;
int ValmaxHum = 75;
int minADC1 = 23;
int maxADC1 = 865;
int minADC2 = 15;
int maxADC2 = 886;
int minADC3 = 21;
int maxADC3 = 849;
String horaCompleta;  // Variable global para almacenar la hora completa
String fechaHoraFormateada;
  pinMode(Ventilador, OUTPUT);
  digitalWrite(Ventilador, HIGH);
  // pinMode (EstadoVentilador, INPUT_PULLUP);
  if (!sht31.begin(0x44)) {
    Serial.println("Couldn't find SHT31");
    while (1) delay(1);
  pinMode(LEDR, OUTPUT);
  pinMode(LEDG, OUTPUT);
  pinMode(LEDB, OUTPUT);
  digitalWrite(LEDR, HIGH);
  digitalWrite(LEDG, HIGH);
  digitalWrite(LEDB, HIGH);
  // Inicialización del módulo celular
  cellular.begin();
  // Intentar desbloquear la SIM si se proporciona un PIN
  if (String(SECRET_PINNUMBER).length() > 0 && !cellular.unlockSIM(SECRET_PINNUMBER)) {
    Serial.println("Fallo al desbloquear la SIM. Continuando...");
  // Conexión a la red celular
  Serial.println("Conectando...");
  if (!cellular.connect(SECRET_GPRS_APN, SECRET_GPRS_LOGIN, SECRET_GPRS_PASSWORD)) {
    Serial.println("Fallo al conectar a la red. Reintentando en el loop...");
    Serial.println("Conectado!");
    client.setServer(mqtt_server, mqtt_port);
    client.setCallback(callback);
ledSequence();
// La función callback
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Mensaje recibido [");
  Serial.print(topic);
  Serial.print("]: ");
  // Convertir el payload a un string
  String message;
  for (int i = 0; i < length; i++) {
    message += (char)payload[i];
  Serial.println(message);
  // Crea un objeto JSON a partir del mensaje recibido
  StaticJsonDocument<200> doc;
  DeserializationError error = deserializeJson(doc, message);
  // Verifica si hubo un error al parsear el JSON
  if (error) {
    Serial.print("Error al parsear JSON: ");
    Serial.println(error.c_str());
    return;
  // Si el mensaje es para el topic "Propagador/ValmaxHum", extraemos y actualizamos la variable ValmaxHum
  if (String(topic) == "Propagador/ValmaxHum") {
    int valor = doc["valor"]; // Extrae el valor del JSON
    // Actualiza ValmaxHum
    ValmaxHum = valor;
    Serial.print("ValmaxHum actualizado a: ");
    Serial.println(ValmaxHum);
    ledSequence3();
bool reconnect() {
  Serial.print("Intentando conexión MQTT...");
  // Desconectar el cliente MQTT antes de intentar reconectar
  client.disconnect();
  if (client.connect("Semillero", mqtt_user, mqtt_password)) {
    Serial.println("Conectado");
    ledSequence3();
    // Suscribirse a los temas
    client.subscribe("Propagador/Garaje");
    client.subscribe("Propagador/ValmaxHum");  // Suscripción al topic para recibir el valor de ValmaxHum
    return true;
    ledSequence2();
    Serial.print("Fallo, rc=");
    Serial.print(client.state());
    Serial.println(" intentando de nuevo más tarde");
    return false;
  LecturaSensores();
  Serial.print("Valor Maximo Humedad: ");
  // Control del ventilador basado en la humedad
  if (HumedadSemillero >= ValmaxHum) {
    digitalWrite(Ventilador, LOW);
    InversorEstado = 1;
    Serial.println("Ventilador activado");
  } else if (HumedadSemillero < (ValmaxHum - 1)) {
    InversorEstado = 0;
    Serial.println("Ventilador Desactivado");
  ControlVentilador = digitalRead (EstadoVentilador);
  if (ControlVentilador == 1) {
    InversorEstado = 0;
  if (ControlVentilador == 0) {
    InversorEstado = 1;
  unsigned long now = millis();
  // Gestión de la conexión MQTT
  if (!client.connected()) {
    if (inPause) {
      // Si estamos en la pausa, comprobar si ha pasado el tiempo de espera
      if (now - reconnectionPause > 30000) {  // 30 segundos de espera
        inPause = false;  // Terminar la pausa y permitir intentos de reconexión
        reconnect_attempts = 0;  // Reiniciar el contador de intentos de reconexión
      // Intentar reconectar si no estamos en pausa
      if (now - lastReconnectAttempt > 5000) {  // Intentar reconectar cada 5 segundos
        lastReconnectAttempt = now;
        if (reconnect()) {
          reconnect_attempts = 0;  // Reiniciar contador de intentos si se reconecta exitosamente
          reconnect_attempts++;
          if (reconnect_attempts > max_reconnect_attempts) {
            reconnectionPause = millis();  // Iniciar la pausa
            inPause = true;  // Activar la pausa
            Serial.println("Número máximo de intentos de reconexión alcanzado. Pausando antes de intentar nuevamente...");
    client.loop();
    // Publicar un mensaje cada 10 minutos
    if (now - lastMsg > publishInterval) {
      lastMsg = now;
      ObtenerHora();
      PublicarHoraFormateada ();
      // Crear objeto JSON
      StaticJsonDocument<256> doc;
      doc["HumedadSemillero"] = String (HumedadSemillero, 2);
      doc["TemperaturaSemillero"] = String (TemperaturaSemillero, 2);
      doc["MoistureValue1"] = mappedValue1;
      doc["MoistureValue2"] = mappedValue2;
      doc["MoistureValue3"] = mappedValue3;
      doc["InversorEstado"] = InversorEstado;
      doc["ValmaxHum"] = ValmaxHum;  // Añadir ValmaxHum al mensaje JSON
      doc["HoraCompleta"] = horaCompleta; // Añadir hora completa al JSON
      // Convertir JSON a string
      char buffer[256];
      size_t n = serializeJson(doc, buffer);
      Serial.print("Publicando mensaje: ");
      Serial.println(buffer);
      // Publicar con retención
      client.publish("Propagador/Garaje", (const uint8_t*)buffer, n, true);
void ledSequence() {
  // Control de LEDs
  digitalWrite(LEDR, HIGH); //Encendemos Led Azul
  digitalWrite(LEDB, LOW);
void ledSequence2() {
  // Control de LEDs
  digitalWrite(LEDR, LOW);  //Encendemos led Rojo
  delay (1000);
void ledSequence3() {
  // Control de LEDs
  digitalWrite(LEDR, HIGH); //Encendemos led Verde
  digitalWrite(LEDG, LOW);
**************************************** SUBPROGRAMAS*****************************************************************************
void ObtenerHora() {
    Time time = cellular.getCellularTime();
    // Verifica si la cadena ISO 8601 no está vacía, lo que indica que se ha recibido un tiempo válido
    if (!time.getISO8601().isEmpty()) {
        // Imprime la hora en formato ISO 8601
        Serial.print("Current time (ISO8601): ");
        Serial.println(time.getISO8601());
        // Lee la cadena ISO 8601 desde el objeto Time
        String isoTime = time.getISO8601();
        // Encuentra el índice del delimitador 'T'
        int T_index = isoTime.indexOf('T');
        // Extrae la fecha completa (antes de la 'T')
        String fechaCompleta = isoTime.substring(0, T_index);
        // Separa el año, mes y día
        String anio = fechaCompleta.substring(0, 4);
        String mes = fechaCompleta.substring(5, 7);
        String dia = fechaCompleta.substring(8, 10);
        // Extrae la hora completa (después de la 'T' hasta el final)
        String horaCompleta = isoTime.substring(T_index + 1);
        // Elimina la parte +00:00 si está presente
        int plusIndex = horaCompleta.indexOf('+');
        if (plusIndex != -1) {
            horaCompleta = horaCompleta.substring(0, plusIndex);  // Elimina +00:00
        // Formatea la fecha y hora como DD-MM-AAAA HH:MM:SS
        fechaHoraFormateada = dia + "-" + mes + "-" + anio + " " + horaCompleta;
        // Imprime la fecha y hora formateada
        Serial.print("Fecha y Hora Formateada: ");
        Serial.println(fechaHoraFormateada);
        // Si necesitas trabajar con las horas, minutos y segundos individualmente:
        int colon_index1 = horaCompleta.indexOf(':');
        int colon_index2 = horaCompleta.indexOf(':', colon_index1 + 1);
        // Extrae las partes de la cadena
        String hourString = horaCompleta.substring(0, colon_index1);
        String minuteString = horaCompleta.substring(colon_index1 + 1, colon_index2);
        String secondString = horaCompleta.substring(colon_index2 + 1, colon_index2 + 3);
        // Convierte las partes a enteros
        HoraReferencia = hourString.toInt();
        MinutosReferencia = minuteString.toInt();
        SegundosReferencia = secondString.toInt();  // Corrección aquí: usar .toInt() en vez de ()
        // Llama a la función para formatear la hora completa
        formatTime();
        // Imprime los valores de hora, minutos y segundos
        Serial.print("Horas: ");
        Serial.println(HoraReferencia);
        Serial.print("Minutos: ");
        Serial.println(MinutosReferencia);
        Serial.print("Segundos: ");
        Serial.println(SegundosReferencia);
        Serial.println("No se pudo obtener el tiempo válido.");
void LecturaSensores () {
    HumedadSemillero = sht31.readHumidity();    // Leemos el sensor de humedad ambiente.
    Serial.print("Humedad Semillero = ");
    Serial.println(HumedadSemillero);
    TemperaturaSemillero = sht31.readTemperature();   // Leemos el sensor de Temperatura ambiente exterior.
    Serial.print("Temperatura Semillero = ");
    Serial.println(TemperaturaSemillero);
    //**********LETS READ THE WM1 SENSOR ON CHANNEL 1**************
    // first take reading through path A
    moistureValue1 = analogRead(analogInPin1);
    Serial.print("ADC1 = ");
    Serial.print(moistureValue1);
    Serial.print(", ");
    mappedValue1 = map(moistureValue1, minADC1, maxADC1, 0, 100);
    Serial.print("Moisture value1 = ");
    Serial.println(mappedValue1);
    //**********LETS READ THE WM2 SENSOR ON CHANNEL 2**************
    moistureValue2 = analogRead(analogInPin2);
    Serial.print("ADC2 = ");
    Serial.print(moistureValue2);
    Serial.print(", ");
    mappedValue2 = map(moistureValue2, minADC2, maxADC2, 0, 100);
    Serial.print("Moisture value2 = ");
    Serial.println(mappedValue2);
//**********LETS READ THE WM2 SENSOR ON CHANNEL 3**************
    moistureValue3 = analogRead(analogInPin3);
    Serial.print("ADC3 = ");// print ADC results to the serial monitor:
    Serial.print(moistureValue3);
    Serial.print(", ");
    mappedValue3 = map(moistureValue3, minADC3, maxADC3, 0, 100);
    Serial.print("Moisture value3 = ");
    Serial.println(mappedValue3);
void formatTime() {
    // Formatear cada parte de la hora, minuto y segundo con ceros a la izquierda si es necesario
    String hourString = (HoraReferencia < 10) ? "0" + String(HoraReferencia) : String(HoraReferencia);
    String minuteString = (MinutosReferencia < 10) ? "0" + String(MinutosReferencia) : String(MinutosReferencia);
    String secondString = (SegundosReferencia < 10) ? "0" + String(SegundosReferencia) : String(SegundosReferencia);
    // Concatenar la hora completa en formato HH:MM:SS
    horaCompleta = hourString + ":" + minuteString + ":" + secondString;
void PublicarHoraFormateada() {
    reconnect();
  String payload = String(fechaHoraFormateada);
  // Publicar el dato con retención activada
  if (client.publish("Propagador/Fecha&HoraAmbiente", payload.c_str(), true)) {
    Serial.println("Dato de Fecha&Hora publicado correctamente con retención");
    Serial.println("Error al publicar dato de Fecha&Hora");
arduino_secret.h
#define SECRET_PINNUMBER “pin” // replace with your SIM card PIN
#define SECRET_GPRS_APN  “apn” // replace with your GPRS APN
#define SECRET_GPRS_LOGIN    “user”    // replace with your GPRS login
#define SECRET_GPRS_PASSWORD “password” // replace with your GPRS password
#define SECRET_SERVER_MQTT “your server” // Server MQTT
#define SECRET_USER_MQTT “user mqtt”
#define SECRET_PASSWORD_MQTT “password mqtt“
#define SECRET_PORT_MQTT “port mqtt”
Hi Luis, Thank you for being so generous! Much appreciated!!
Hi Luis. Thank you. May I ask if the code that you shared above, the part where data is sent to your own EMQX server is working? Thanks again!
Hello, the code I have provided you is working correctly. I currently have it working in a seedbed that I have in production. It controls the soil humidity of three trays, the ambient humidity and the ambient temperature. And the switching on and off of a fan that is activated based on the ambient humidity and the threshold set by the reception of mqtt data.
Understood. Thank you Luis. Very grateful.
