Arduino midi casio ca-110
ola pessoal tenho um projeto que esta funcionando perfeitamente que peguei de um video na internet mas gostaria de alterar ele por causa que tem as apenas a opção de 2 oitavas gosta de saber se não teria alguem pra me ajudar a fazer essa alteração
o video : https://www.youtube.com/watch?v=E_sVH_25VEE&ab_channel=SolveIT
e o codigo : // Pin Definitions
// Rows are connected to
int fsr1 = 50; // Kolumna 1 FSR
int fsr2 = 48; // Kolumna 2 FSR
int fsr3 = 46; // Kolumna 3 FSR
const int s0 = 49; // Szary - multiplexer
const int s1 = 51; // Bialy - multiplexer
const int s2 = 53; // Czarny - multiplexer
const int Clock = 39; // ShiftOut
const int latch = 41; // ShiftOut
const int data = 43; // ShiftOut
int octave = 1;
void velodown(){ if(octave == 2){ octave = octave - 1; }
void veloup(){ if(octave == 1){ octave = octave + 1; }
void scanColumn(int value) {
digitalWrite(latch, LOW); //Pulls the chips latch low
shiftOut(data, Clock, MSBFIRST, value); //Shifts out the 8 bits to the shift register
digitalWrite(latch, HIGH); //Pulls the latch high displaying the data
boolean stan1 = false;
boolean stan2 = false;
int r0 = 0; //value of select pin at the 4051 (s0)
int r1 = 0; //value of select pin at the 4051 (s1)
int r2 = 0; //value of select pin at the 4051 (s2)
int bits[] = { B00000001, B00000010, B00000100, B00001000, B00010000, B00100000, B01000000, B10000000 };
int keyToMIDI0[8][6] = {
{37,38,36,39,41,40},
{55,56,54,57,59,58},
{49,50,48,51,53,52},
{43,44,42,45,47,46},
{31,32,30,33,35,34},
{25,26,24,27,29,28},
{19,20,18,21,23,22},
{13,14,12,15,17,16},
boolean keyPressed[8][6] = {
{false,false,false,false,false,false},
boolean FSRKeys[3][2] = {
{false,false},
{false,false},
{false,false},
int FSRMidi[3][2]{
{0,1}, //
{250,252}, // Start i Stop - wiersz 3 (zielone guziki)
{2,3},
void noteOn(int cmd, int pitch, int velocity) {
Serial.write(cmd);
Serial.write(pitch);
Serial.write(velocity);
pinMode(s0, OUTPUT); // s0 multiplexer pinout
pinMode(s1, OUTPUT); // s1 multiplexer pinout
pinMode(s2, OUTPUT); // s2 multiplexer pinout
pinMode(data, OUTPUT); // ShiftOut data pinout
pinMode(Clock, OUTPUT); // ShiftOut clock pinout
pinMode(latch, OUTPUT); // ShiftOut latch pinout
pinMode(fsr1, OUTPUT); // Kolumna 1 FSR
pinMode(fsr2, OUTPUT); // Kolumna 2 FSR
pinMode(fsr3, OUTPUT); // Kolumna 3 FSR
FSRMatrix();
for (int col = 0; col < 8; col++) {
scanColumn(bits[col]);
int rows[6] = {0,1,3,5,6,7};
for (int row = 0; row < 6; row++) {
int real_row = rows[row];
r0 = bitRead(real_row,0);
r1 = bitRead(real_row,1);
r2 = bitRead(real_row,2);
digitalWrite(s0, r0);
digitalWrite(s1, r1);
digitalWrite(s2, r2);
int value = analogRead(A0);
if(value > 300){
if(!keyPressed[col][row] ){
if(octave == 2){
noteOn(144,keyToMIDI0[col][row] + 48,127);
}else{
noteOn(144,keyToMIDI0[col][row],127);
keyPressed[col][row] = true;
else{
                  if(keyPressed[col][row]){
                    if(octave == 2){
                    noteOn(128,keyToMIDI0[col][row] + 48,127);
                    }else{
                     noteOn(128,keyToMIDI0[col][row],127);
                    keyPressed[col][row] = false;
void FSRMatrix() {
int cols[3] = {7,6,12};
int rows[2] = {1,2};
for(int i=0;i < 3;i++){
digitalWrite(cols[i], HIGH);
for(int j = 0;j < 2;j++){
int value = analogRead(rows[j]);
if(value > 300){
if(!FSRKeys[i][j] ){
if(i==2&&j==0){ velodown(); }
else if(i==2&&j==1){ veloup(); }
else{
Serial.write(FSRMidi[i][j]);
FSRKeys[i][j] = true;
else{
if(FSRKeys[i][j]){
FSRKeys[i][j] = false;
digitalWrite(cols[i], LOW);
