Hi!
I am planning to buy Arduino Mini and a bluetooth module so I could control it using Pocket PC.
I would like to know if these are compatible. I am quite beginner in this field, so I hope someone could help me. There is SparkFun BlueSMiRF modem, which is specially designed for Arduino boards, but unfortunately it is not sold in my country. And I dont want to buy it from e-shop, beacause the transport takes long time and will cost much.
A surface mounted module designed to be built into a device. The module is optimized for applications which communicate against systems with USB bluetooth stack, like Windows CE and XP. Available with or without built-in aerial. Transmission rate up to 3 Mbps and approx. 300 m range.
- Interface: Bluetooth - HCI*
- Bluetooth: Class 1 version 2.0+EDR*
- Supply voltage: +5 V*
- Supply current: [ch8804]30 mA*
- Frequency: 2.400 to 2.485 GHz*
- Power min/max: [ch8722]27 / +6 dBm*
- Sensitivity: [ch8722]86 dB min*
- Temp. range: [ch8722]40 to +85 °C*
- Dim.: 17.7×46×5 mm*
- Weight: 8 g*
What is HCI interface and is it compatible with Arduino Mini? And is it a bluetooth MODEM?
