Arduino MINI - IoT measurement temperature - sleep LOW POWER
Hello,
I know that there’s many contributions of sleep processor. I wonder but the best solution for my device. I need the processor via UART has sent a message and then put under at least 30 minutes and again. What will be the most economical solution?
#include <Akeru.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define TX 2
#define RX 3
#define ONE_WIRE_BUS 7
float temperatureInCelsius;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
Akeru akeru(RX, TX);
int  TempInC;
  Serial.println("Starting...");
  // Check TD1208 communication
  if (!akeru.begin())
    Serial.println("TD1208 KO");
    while(1);
/*  delay(100);
   if (!akeru.begin())
    while(1);
  delay(100);
sensors.requestTemperatures();
sensors.getTempCByIndex(0);
TempInC = sensors.getTempCByIndex(0);
delay(100);
 temperatureInCelsius = sensors.getTempCByIndex(0); // EDIT:  instaed of here
  //int sensorValue = analogRead(A0);
  // Trace on serial console
   Serial.print(temperatureInCelsius, 3);
  // convert to hexadecimal before sending
  //String data = String(temperatureInCelsius);
 delay(200);
  String data = akeru.toHex(temperatureInCelsius);
 // Serial.print ((temperatureInCelsius);
  // Send in the mighty internet!
  // akeru.sendPayload() returns 0 if message failed.
  delay(600);
  if (akeru.sendPayload(data))
    Serial.println("Message sent !");
this will be the solution?
#include "LowPower.h"
const byte LEDpin = 13;
    pinMode(LEDpin, OUTPUT);
     LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
void blik()
    digitalWrite(LEDpin, HIGH);
    delay(100);
    digitalWrite(LEDpin, LOW);
