I have a small programme which uploads and runs on a Nano 3 without problems.
I want to save space by using a Mini instead.
When I simply connect an Arduino Mini via a USB-Serial adapter (4-wire,5V, Gnd, TX, RX) to my PC, I get a power LED lit and it runs the "Blink" program flashing pin13 LED ( so power connection is OK and so is the 328P ?)
But my good programme won't load to the Mini. "programmer is not responding" error message and no "data" LED flashes on the Mini... so it's some kind of Comms problem?
Microsoft Device Driver says the Silabs USB-UART device is working properly on COM6 and the driver name includes "Silabs" name. The Arduino IDE also says COM6 is being used.
I've tried the suggested "resetting" tricks, swapped the TX/RX pins, tried 3 different USB-UART devices, swapped Minis ... all to no avail.
HELP! .....It beats me! ...I would appreciate any good ideas
As Confucius [would have] said "most faults are simple, it's finding them that's hard!" - Lol!
With the comment that you should can press the reset button at the moment that you're close to the uploading stage and release immediately after the message about the memory usage shows.
What serial-USB adapter are you using? Is it missing the DTR pin? Or is there a reason you didn't connect the DTR line?
After playing around with Pro Minis I'll never buy a serial-USB adapter that doesn't have the DTR line broken out. It saves so much hassle.
That's true, but they are very similar and the page you linked above shows how to program the Mini using the Reset line in addition to power and TX/RX.
I got diverted by news of the the death of a friend (on another internet forum).
I believe that my device is a Mini, not a pro Mini.... I'll double check.
It's Chinese sourced ... very cheap, but with all that implies! .. Nano 3's from the same source work fine.
I did choose the correct board in the IDE and it showed the correct processor, comms port, etc.
I don't have a DTR output available on any of the 3 USB-SERIAL adapters I own. However, I note that other people seem to get things to work with only 4-wires (Batt, Gnd, TX, Rx) plus, maybe, the Mini's reset button.
I'll do a bit more research on the use of the DTR facility
I note that the Mini has a DTR pin. I haven't connected to it
The only reason that I'd like to use a Mini (rather than a Nano 3) is because it's smaller and would make a neater project package.
I'm a bad looser! I don't like letting inanimate objects beat me!- Lol!
On reflection, maybe, it's time for me to forego neatness and elegance in favour of convenience and the "simpler life"..... I'll use a Nano 3 ...I'm 83 ...So many good things still to do ...So little time!
