I have an Arduino Mini Pro 3.3 V powered from a coin cell(3.6 V, CR2450) and connected to Bluetooth Mate Gold. I have checked the connections and they are fine. I can also connect to the bluetooth from while trying to upload the file and also from Android bluetooth terminal.I am not sure if it could be bootloader issue as I have checked 2 Arduino Mini Pros that give the same problem running the sample sketch on the bluetooth hookup guide.
Arduino: 1.6.5 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
Sketch uses 2,412 bytes (7%) of program storage space. Maximum is 30,720 bytes.
Global variables use 210 bytes (10%) of dynamic memory, leaving 1,838 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Thanks.
