I'm looking into some lower voltage options from the 5v Arduino Uno. I was looking at the Arduino Pro Mini @ 3.3v however, I was wondering if anyone knows anything in regards to a compatible LCD screen it doesn't have to be 16x2, I'm really just looking for an LCD that would be able to run from 3.3v minimum, and maybe like 4.18 max. If anyone has any ideas please let me know, Thank you!
Take a look at newhavendisplay.com, they have a lot of choices, maybe there are some that will fit your needs.
Where's the 4.18 Max come from?
Sounds good, I'll take a look. As for the 4.18v max, that would be the max output voltage of a 18650 battery I'm using for the project. At full charge they ring in at 4.18v. Thanks again for the help!
I found one on sale at NewHavenDisplay.com
http://www.newhavendisplay.com/nhd0420azflgbw3v3-p-2003.html
The only thing that made me second guess, was the Controller/Driver: SPLC780D OR ST7066U, I wasn't positive that it would be compatible. From what I have read this would not be an issue, so I picked up 2 of them. I was a fan of this model because it only needs 2.7v min with typical being 3v and max at 3.3v and low mA so it won't kill the battery life either. It's perfect for my application. I really hope I don't have any issues with the drivers though... Staying positive and keeping my fingers crossed.
Peter9DO:
No comment on the 4.18v, but the Nokia 5110 would have to be an obvious choice. It is designed run on 3.3v.
Display is 12x6 but you can often get an extra character or two on a line.
