I want to upload only one sketch to my arduino mini pro and then use it in my project.
Is it possible to power the Arduino mini pro with only the + and - from a stripped USB cable going to RAW and GND?
or do i need to get the USB - serial converter and attach it to the board?
Thank you,
joethemaker:
Thank you,
If your CPU runs at 3.3 Volts then
yes you can simply apply, more than, 3.3 Volts to RAW & GND.
If the Pro Mini is the 5V version, then you want the USB power connected to the 5V rail, not RAW.
Thank you both for your help.
I will try this tonight and let you know how it goes.
Thanks again,
Joe
