Arduino Mini , problem with Voltage read
I am using a voltage divider so I can monitor the voltage a 3cell lipo.
The problem is that the SerialRead gives 1023 (max) even when the voltage is at 2.19V across Arduino Gnd and Arduino A0
So I am dropping the voltage from ~10 to 2.19 but the arduino reads 5V (ie 1023)
I have attached a schematic of my setup.
I suppose the problem might be that I need a reference voltage, as maybe one from the board the 5V? In that case how would I need to wire it to correct the serialRead.
Here is my code as well:
const int analogPin=A0;
int val=0.0;
void setup(){
void loop(){
val=analogRead(analogPin);
Serial.println(val);
What I am trying to do is use the mini to monitor voltage of a lipo and then will hook up a relay to switch off the circuit if the voltage drops below a certain value. I am using the mini so I can save as much weight as possible. Not sure if there is another board that could do the same thing with less weight maybe?
Thanks, and I think this is my first post in this forum too :slight_smile:
  1. Please use code tags when posting code.
  2. Try changing the first 2 lines to:
const int analogPin=0;
int val=0;
A0 is what you call analog pin 0 when you are using it as a digital pin. It's just 0 when you are using it in an analogRead call. I don't know whether calling A0 will work in that context.
  1. If your voltage divider is 4K to +10V and 4.7K to ground as indicated in your diagram, then the voltage at the centre won't be below 5V. Check your calculations.
