arduino mini project
I am trying to find some components which will measure the tempreture and the % of the moist in the air.
A thermometer to find the tempreture and send it back to the processor and if the tempreture is above 28 degree C it will activate a fan , and if its below 22 degree C it will power up a heat source.
A hygrometer which measure the moist un the air ,and again according to a condition will activate another component.
My choice is the Si7021. The modules are cheap, small and have I2C.
Bosch BME280 - also measures air pressure
aarg:
i have red little bit about the module
i have never tried using a modules like this and i cannot understand the data sheets
can u sum up the basics?
also i need a Measure PH levels in ground there is anything u farmiliar with?
DHT22 is yet another option. Temp & humidity, one-wire data bus (needs dedicated IO pin on your Arduino, no I2C goodness)
evya61992:
I use an existing library. I have never read the data sheet. It works like a charm.
aarg:
can u send me the library
evya61992:
Ever heard of Google? " Arduino library" usually does the trick.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Can you tell us your electronics, programming, Arduino, hardware experience?
i have used aruino to make a project to my finales diploma (electronics)
