Hello Team, i have an issue with my arduino MKR1400, im giving a HIGH output to the arduino relay board from pin number 2 it is working fine but from all other pin not working, does other pins giving different value of the current or the board is damaged how i can check?
If you are using the MKR relay shield then relay-1 is hardwired to pin 1 and relay-2 is hardwired to pin 2, you can't use any other pins.
Moved to Project Guidance..... As you need guidance for what is wrong.
Hello, i am not using mkr shield im using normal shield for arduino, and even without the relay for a normal LED the LED glow is fine from pin number 2 and fade from other pin
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Edited topic title to reflect this, please be more specific in future.
Hello Team, i have an issue with my arduino MKR1400, im giving a HIGH output to the normal arduino relay board from pin number 2 it is working fine but from all other pin not working, and even with the LED its glowing fine with pin number 2 and fade from other pins does other pins giving different value of the current ?
Another cross-post merged. @keirone you have already been warned against doing that. Your behavior is disrespectful to this community of people who are trying to provide you with free assistance. If you continue this behavior, it will result in a suspension of your account.
