Arduino MKR 1500 + NB Client
MKR 1500 + NB Library.
I am having issues in my code when a new connection is attempted to be established at client.connect(server, port);
Arduino gets frozen when a new connection is made without internet access. It simply never respond. There is no timeout.
Code:
// libraries
#include <MKRNB.h>
// initialize the library instance
NBClient client;
GPRS gprs;
NB nbAccess;
// URL, path and port (for example: example.org)
char server[] = "example.org";
char path[] = "/";
int port = 80; // port 80 is the default for HTTP
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Starting Arduino web client.");
  // connection state
  boolean connected = false;
  while (!connected) {
    if ((nbAccess.begin() == NB_READY) && (gprs.attachGPRS() == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  Serial.println("connecting...");
  //if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    Serial.print((char)client.read());
  // if you get a connection, report back via serial:
  if (client.connect(server, port)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.print("GET ");
    client.print(path);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  //if the server's disconnected, stop the client:
  if (!client.available() && !client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
As you can see, I have commented out the block of the code which connects to the internet on purpose. As I understand, the line client.connect(server, port) shouldn't hang forever, it should go to else condition and print a message saying "connection failed". This is a very common scenario where internet is not available 24x7. It seems a library bug.
Does anybody have ever faced this issue before? Is there a workaround?
Thank you!
Wrong, if you want that behavior you have to call the library correctly:
NBClient client(false);
Otherwise the NBClient.connect() method waits until the internet connection gets ready, if you explicitly prohibit this it will wait forever.
Thank you so much for the advice Pylon. I will test!.
Cheers.
