I have an Arduino MKR GSM 1400 that I want to be able to fetch the current GPS position (using a separate GPS module) with and send it to a web server (API).
I've tried to use the Adafruit GPS library. First, I tried using the SoftwareSerial library but I got the following error:
This version of SoftwareSerial supports only 20, 16 and 8MHz processors
So I've tried using the HardwareSerial. Does anyone know which ports of the GPS module should be connected to which ports on the Arduino MKR GSM? Is this whole thing even going to work or do I need something else?
Yes, I've tried connecting serial 13 (RX) to the "RX" port of my GPS module and serial 14 (TX) to the TX port of my GPS module. The only other thing I can vary is the "baud rate" which should be 9600 according to the specification of the GPS module I initially posted.
